Thermodynamics (sort of) for a non engineer
In summary, if you want to cool a building using water, you will need to calculate the water flow and the energy needed to be removed. The math is the same as for heating.
stryped
51
I have a 30 by 30 shop with insulation and 10 foot ceilings. I have been reading about geothermal and it got me curious. If I were to bury 1 inch PVC type pipe and ran water and radiator fluid or water and some type of alcohol like windshield washer fluid is there a formula to determine the amount I would need to cool this building? I thought about running it through a radiator. Mind you this is mainly just an experiment. Not looking to make it as comfortable as the inside of my house but to keep temp more comfortable in the hot summer season of southern ky.
I have 5 acres. I planned to build a pipe laying attachment for my tractor. I know the only problem will be depth. I can probably get the pipe between 1 and 3 feet underground. To help compensate, i could lay rigid insulation on the top side of the trench.
What do you think?
Why PVC pipe? You want to design a heat exchanger. That is a system that exchanges heat between the pipes and the ground. You will need to use pipes that conduct heat.
It will not work at all unless there is a temperature difference between the shop and the ground. You are not using a heat pump so you are simply cooling by conducting heat to or from the ground. In order for that to work at all you need to maximize temperature difference between the shop and the ground ie. between the surface temperature and the underground temperature.
AM
I am hoping there will be a temperarure differential or at least a lag.
The choice of plastic pipe is because it can be purchased in coils of several hundred feet and is relatively inexpensive. Copper does not come in coils of 1 inch diameter and if it did would be astronomical in price
Likes jim hardy
You need a heat pump. You will not be able to cool or heat your shop without using a heat pump cycle. That requires a good refrigerant fluid, a compressor, a throttle and a heat exchanger. You certainly cannot do it with plastic pipes. Just look at the back of any refrigerator. Have you ever seen one with plastic piping at the back?
AM
Ok. Another thing I have wondered...
I actually have a used 2 ton heat pump in storage. I have often wondered, would burying the liquid and suction lines a certain amount increase efficiency by using the Earth as a sort of heat sink to reduce the hot gasses? This is a regular heat pump, not a geothermal designed one.
He can. Plastic pipes are the standard (because of the reasons OP has already mentioned) as the ground part of such systems.
The math is ~ the same as for heating: you have a temperature difference between the inside and outside, and with the data of the house it is possible to calculate the energy needed for heating (energy needed to be removed in case of cooling). With the temperature change of water you can calculate the water flow.
But if you look around there are plenty of homepages about such calculations for heating. It is easy to adjust them for cooling.
The radiator is tricky, expect excess moisture on the cooling surface. Also, three feet might not be enough/optimal, but if you have the right type of soil there you might get it cheaper with drilled wells.
Likes jim hardy
This is a great thread. Let's move it to DIY where it should be.
Did you try youtube? This guy seems to be doing what you want. Note that geothermal cooling also works for heating in cold months. ...since we have a divergence of opinions here, @russ_watters could help, too.
I lived nextdoor to a guy who installed Geothermal in New Mexico. Per Carl H: Minimum depth has to be well below the dry line in the soil. That's the point in the driest weather you have where the soil is still moist from capillary movement of deeper water upwards. Where I live this is 8 feet. o0)
Also consider frost depth.
Find out what those depths are where you live before you do all this work. You may have shallow bedrock, too.
Your USDA county agent can tell you all of this stuff.
Related to Thermodynamics (sort of) for a non engineer
1. What is thermodynamics?
Thermodynamics is the branch of physics that deals with the study of heat, energy, and work, and their interrelationship with matter. It is a fundamental concept in understanding how energy is transferred and transformed in various systems.
2. How does thermodynamics apply to everyday life?
Thermodynamics is present in many aspects of our daily lives, from the functioning of our bodies to the operation of machines. It explains the transfer of heat between objects, the conversion of energy from one form to another, and the behavior of gases and fluids.
3. What are the laws of thermodynamics?
The laws of thermodynamics are fundamental principles that govern energy and its interactions. The first law states that energy cannot be created or destroyed, only transferred or transformed. The second law states that the total entropy of a closed system will always increase over time. The third law states that it is impossible to reach absolute zero temperature through a finite number of steps.
4. What is the difference between heat and temperature?
Heat and temperature are often used interchangeably, but they are not the same. Heat is a form of energy that is transferred between objects due to a temperature difference. Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance.
5. How is thermodynamics related to energy efficiency?
Thermodynamics plays a crucial role in understanding and improving energy efficiency. By applying the laws of thermodynamics, engineers and scientists can design systems that minimize energy losses and maximize the useful work output. This is important in reducing our overall energy consumption and promoting sustainable practices.
  • DIY Projects
  • General Engineering
  • Mechanical Engineering
