Thermodynamics: Stiff and isolated container
In summary, when an isolated system experiences a change in temperature, the internal energy of the products relative to the reactants must be negative in order for Q to be negative. In this case, the temperature of the water vapor must rise above the original temperature of the hydrogen and oxygen.
Karol
1,380
A stiff and isolated vessel contains oxygen and hydrogen. a spark is made and explosion occurs. temperature and pressure rise high. apply the first law.
The first law: ##Q=U_2-U_1+W##
Is the heat generated in the explosion considered incoming heat? if not, U2=U1 but it's not logical, how can the final state, with it's higher pressure and temperature be equal to the initial? can the internal energy be the same?
No, it is change of the chemical energy of the constituents. If chemical reaction can occur in a system, you have to include chemical energy to the internal energy.
Yes, you are correct. The internal energy is the same. But, how can this be?
What would you have to do if the reactor were not isolated, and you wanted the final temperature of the water to be the same as the initial temperature of the hydrogen and oxygen (assuming in the final state, the water is still a vapor)? What does that tell you about the internal energy of the water (final state) at that constant temperature compared to the internal energy of the reactants (initial state)?
Chet
Maybe i don't understand but if i want to cool the vapor i would take out heat from the reactor, and it shows that the internal energy of the hot vapor in the final state is higher than at the beginning because temperature is a measure of internal energy, so the less i understand
You almost had it. If, to maintain the temperature constant, you need to remove heat, the internal energy of the products relative to the reactants must be negative. We call such a reaction "exothermic" and we say that the "heat of reaction" (the internal energy change at constant temperature) is negative. That is, in order for Q to be negative, ΔU must be negative to maintain constant temperature. Now if, in the isolated system, ΔU = 0, that means that the temperature of the water vapor must rise above the original temperature of the hydrogen and oxygen.
Chet
FAQ: Thermodynamics: Stiff and isolated container
What is a stiff and isolated container in thermodynamics?
A stiff and isolated container in thermodynamics is a theoretical concept used to study the behavior of gases under certain conditions. It assumes that the container is rigid and cannot expand or contract, and that it is completely isolated from its surroundings, meaning no energy or matter can enter or leave the container.
How does a stiff and isolated container affect gas molecules?
In a stiff and isolated container, gas molecules are forced to collide with one another and with the walls of the container. This results in an increase in pressure and temperature, as the molecules have no room to escape and their kinetic energy is converted into heat.
What are the implications of using a stiff and isolated container in thermodynamics experiments?
The use of a stiff and isolated container in thermodynamics experiments allows for the study of gas behavior under ideal conditions, without external factors influencing the results. This can help scientists understand the fundamental principles of thermodynamics and make accurate predictions about the behavior of gases in real-world scenarios.
Can a real-world container be considered stiff and isolated?
No, a real-world container cannot be considered completely stiff and isolated. While it may be possible to create a container that is rigid and well-insulated, there will always be some degree of energy or matter exchange with the surrounding environment. However, the concept of a stiff and isolated container is still useful for theoretical studies and can provide valuable insights into gas behavior.
What are some limitations of using a stiff and isolated container in thermodynamics?
One of the main limitations of using a stiff and isolated container in thermodynamics is that it is an idealized concept and does not accurately reflect real-world scenarios. Additionally, it does not account for external factors such as gravity, which can have a significant impact on gas behavior. It is important for scientists to consider these limitations when interpreting results from experiments using a stiff and isolated container.
