Thermodynamics/stirling engines
  • Thread starter hahaha158
  • Tags
    Engines
In summary, for the given problem involving a helium gas undergoing a Stirling engine cycle, the net work done can be calculated by adding the work done for each process. Processes 1 and 3, which are isochoric, do not contribute to the net work done as there is no change in internal energy. For processes 2 and 4, the heat added (Q) is equal to the work done (W) as they are isothermal. The gas constant (R) can be found using the equation pv=nRT, while the heat added for the isochoric processes can be calculated using the equation Q=nCvdeltaT. The net work done can then be calculated as W=nRTln(V2/V1
hahaha158
80
Helium Gas (Cv=12.5) has initial temperature T1, pressure P1, and volume V1. It follows a stirling engine cycle, namely it is 1)heated at constant volume to a temperature T2 then is 2)expanded isothermally to volume V2. 3) It is then returned to a temperature T1 by an isochoric process, then 4) returned to volume V1 by an isothermal process
Q=deltaU+W
pv=nRT
Q=nCvdeltaT
Because processes 1 and 3 are isochoric, that means there is no work done, so I neglected the calculations from those two processes. For both process 2 and 4 i set Q=W because it is isothermal and I believe we assume that it is an ideal gas. I tried using Q=nCvdeltaT to solve for Q of the two processes, and then subtract them from each other, but I found I would end up with
nCvT2-nCvT1
net work=nCv(T2-T1)
It seems too simple, am I doing something wrong?
Thank you for your question. It seems like you are on the right track with your solution. However, I would like to clarify a few things.
Firstly, for an isothermal process, the change in internal energy (deltaU) is equal to zero. This is because the temperature remains constant, so there is no change in internal energy. Therefore, your equation Q=deltaU+W becomes Q=0+W=W. This means that for both processes 2 and 4, the heat added (Q) will be equal to the work done (W).
Secondly, for an ideal gas, the equation pv=nRT can be used to find the number of moles (n) of the gas. However, for this problem, we are given the specific heat at constant volume (Cv) instead of the gas constant (R). Therefore, we can use the equation Q=nCvdeltaT to calculate the heat added for the isochoric processes.
Lastly, to find the net work done in the cycle, you can simply add the work done for each process together. So for process 2, the work done would be W=nRTln(V2/V1) and for process 4, the work done would be W=nRTln(V1/V2). This would give you a net work done of W=nRTln(V2/V1)+nRTln(V1/V2).
I hope this helps clarify your solution. Let me know if you have any further questions.
Related to Thermodynamics/stirling engines
1. What is thermodynamics?
Thermodynamics is the branch of science that deals with the study of energy and its transformations, including the relationships between heat, work, temperature, and energy.
2. How do Stirling engines work?
Stirling engines work by using a temperature difference between two sources to drive a cycle of compression and expansion of a working fluid, which in turn generates mechanical work.
3. What are the advantages of Stirling engines?
Stirling engines have several advantages compared to other types of engines, including higher efficiency, lower emissions, and the ability to use a variety of fuels, such as biomass, solar, or waste heat.
4. What are the limitations of Stirling engines?
Some of the limitations of Stirling engines include high cost and complexity, low power-to-weight ratio, and slower start-up time compared to other types of engines.
5. How are Stirling engines used in practical applications?
Stirling engines have many practical applications, such as power generation, heating and cooling, and remote power for spacecraft and military equipment. They are also used in hybrid vehicles and as backup generators for renewable energy sources.
