SpY]
- 65
Two cubic samples of the same dimensions (length L) have thermal conductivities [tex]\kappa_1[/tex] and [tex]\kappa_2[/tex]. The slabs are placed adjacently horizontally | 1 | 2 |
Obtain expressions for the heat flow rate through the composite slab if the temperature difference is applied
a) from top to bottom
b) from left to right
Heat transfer rate: Q' = [tex]\frac{dQ}{dt}[/tex] = [tex]\kappa \cdot A \cdot \frac{\Delta T}{L}[/tex]
Thermal expansion: [tex]\kappa = \frac{\Delta L}{L_0 \Delta T}[/tex]
I'm having trouble even understanding the question. What I can figure out is the above equation to find the expansion length. Then with regard to heat transfer rate, the cross sectional area will be A = 2L² with [tex]\Delta T[/tex] , [tex]\kappa[/tex] and L initially given.
At first guess I'm think for a), the area is 2A (horizontally slice); and for b) its just A (vertical slice). And then just plugged into the equation for heat transfer rate. But the question is for quite a bit of marks so this seems too easy :P
