Matrixhunter
- 3
A 6 cylinder engine has cylinders wirh a bore of 115mm and a stroke of 145mm Each cylinder also has a clearance volume of 300 cubic centimeter. This engine operates on a four stroke ideal otto cycle and at 3000 rpm. The temperature and pressure of the intake air is 25 Celsius and 101kPa respectively. In addition, 900 kJ/kg of heat is rejected during the constant volume heat rejection process. Determine the following
A. total engine displacement
B. Compression ratio for this engine
C. P, V, T, at the four states
D. Wkcycle
E. Power of engine
F. Total heat added per second Qin
G. Efficiency
Not sure
None
Please answer this problem for me step by step with units and coversions with the equations used i need every single detail
