- #36
- 23,434
- 5,748
OK. Let's talk about the process step between points 2 and 3. What can you tell me about that step (in terms of the first law)? What are the conditions at the end of that step?
This is definitely incorrect. You are condensing the vapor to a liquid at constant temperature and pressure. Did you think that the internal energy is a function only of temperature even if there is a phase change? Start with the equation $$\Delta U=Q-P\Delta V$$What does this give you for Q?michealyap said:for process between point 2 and 3, 1st law of thermodynamics , the change of internal energy is equal to zero. so Q=W.
If it is condensed at constant temperature (problem statement), it must be at the equilibrium vapor pressure at that temperature. So the pressure is constant.michealyap said:Q=heat transfer out. how do we know that it is condensed at constant pressure. In the same time, how do we unable to find the internal energy at point 3, which only contain water.
Well, you know that the specific volume at point 2 (averaged over the mass of vapor and liquid) is 0.3066 m^3/kg. And you know that, at point 3, it is all saturated liquid at 0.001091 m^3/kg.michealyap said:ok.. since at point 3 all the water vapor has condensed to become water. the specific internal energy is 631.68 kj/kg for saturated liquid. pressure is 4.758bar. what is the delta V at here? as the formula U2-U3 = Q -PdeltaV .
Specific internal energy = 2135.7 kj/kg at point 2
Specific internal energy = 631.68 kj/kg at point 3
To get the work, you need to subtract the initial volume from the final volume. And, to get the change in internal energy, you need to subtract the initial internal energy from the final internal energy. So, $$P\Delta V=4.758\times 10^5(0.001091-0.3066)=-145000\ J/kg=-145\ kJ/kg$$. And, $$\Delta U=631.68-2135.7=-1504\ kJ/kg=Q-(-145)=Q+145$$ and so $$Q=-1649\ kJ/kg$$michealyap said:it did not work so well for the method 1. change of U = Q - Pdelta V . so, 2135.7 kj/kg - 631.68/kj/kg = Q - 4.758 *10^5 * (0.3066-0.001091(m^3/kg)) , therefore .143.857kj/kg = Q , this the Q i obtained..
For second method how to get the heat of vaporiztion?
