Thermodynamics (work done by unrestrained gas expansion)
In summary, the conversation discusses the possibility of calculating the work when a partition is removed and gas flows into a vacuum. It is noted that the expansion process is rapid and involves zero heat intake, resulting in no change in internal energy for an ideal gas. However, for a non-ideal gas, the temperature may change due to the conversion of kinetic energy into potential energy. It is also mentioned that the expression for work, dW = p dV, is not applicable in this scenario as it only applies to reversible processes. The conversation ends with a question about whether there is a misunderstanding about the concept of work in this situation.
albertov123
https://www.physicsforums.com/attachment.php?attachmentid=20388&stc=1&d=1252066499When the partition removed, gas flows into the vacuum until all system has a uniform pressure. Now, is it possible to calculate the work?
Let's say gas is not an ideal gas.(Freon 12)
We know the volumes of both sides. Also the mass and the initial pressure of gas.
I think we can't use W=PdV because pressure is not constant. Is there a way to do it?
Edit: By the way the temperature will change but in the end returns to its initial value. So heat transfer will occur through the boundaries.
Science news on Phys.org
Since the chamber into which the gas expands is a vacuum, the gas pushes against nothing at all. So, if the outer walls are rigid, the gas does no work. Not so?
The expansion is rapid, much faster than the thermal adjustment time, so the expansion process involves zero heat intake. The internal energy will thus remain constant in the expansion process. If the gas is ideal, this means that the temperature remains the same. If the gas is non ideal, then the kinetic energy of the molecules will suffer as a result of the expansion, leading to a change in temperature. If the forces between the molecules are attractive, then kinetic energy will drain into potential energy, since the average separation of the molecules increases due to the expansion, leading to a drop in temperature.
The reason you cannot use dW = p dV is because this expression for the work done applies only to reversible processes, which are necessarily quasi static. Free expansion is very rapid and definitely not reversible - apart from which pressure waves will travel through the chambers until the pressure equilibrates, which means that between the initial equilibrium state and the final one there is no uniquely defined single value of the pressure in the chamber - the pressure needs to be specified by a pressure field, until it reaches its final constant equilibrium value.
Am I being too naive? Did I misunderstand your question?
Thank you, i understand why there is no work done in the process.
FAQ: Thermodynamics (work done by unrestrained gas expansion)
1. What is thermodynamics?
Thermodynamics is the branch of science that deals with the relationships between heat, work, and energy. It studies the behavior of systems as they undergo changes in temperature, pressure, and volume.
2. What is work done by unrestrained gas expansion?
Work done by unrestrained gas expansion refers to the work that is done by a gas as it expands freely without any external restraint, such as a piston or container. This type of work is commonly seen in processes like the expansion of a gas inside a balloon.
3. How is work calculated in thermodynamics?
In thermodynamics, work is calculated as the product of the force applied and the distance over which the force is applied. In the case of gas expansion, the force is the external pressure and the distance is the change in volume of the gas.
4. What is the first law of thermodynamics?
The first law of thermodynamics states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that the total amount of energy in a system remains constant, but it can change forms.
5. How does the second law of thermodynamics apply to gas expansion?
The second law of thermodynamics states that in any energy transfer or conversion, some energy will inevitably be lost as heat. This means that in the process of unrestrained gas expansion, some of the energy of the expanding gas will be lost as heat, making the process irreversible.
