Thermodynamics: Work, True/False Questions
However, the statement that "no reverse" is true is false, as there can be instances where the expansion of a system is reversible, meaning that no energy is lost due to friction or atmospheric pressure.
CVB
Hello, I have some questions to say true or false.
a) In a P,T,V system always will be true [tex]\int P dv \geq W_{out}[/tex] if the system has friction.
b)In Thermodynamic the work who cross system border is always process function
c)The adiabatic work in Thermodynamic who cross the border in a closed system is independent of process and depends of the final and initial status
d)In a Expansion no reverse it`s true [tex]W_{expansion}=W_{useful}+\left|W_{friction}\right|+W_{atmospheric}[/tex]
Well I think a) and c) are true and b) d) are false
Thank you
for your post and your questions. I can confirm that your answers are correct. Let me explain why.
a) In a P,T,V system, the work done by the system is given by the integral of pressure (P) with respect to volume (V). This is known as the mechanical work, and it represents the energy that is transferred from the system to its surroundings. If the system has friction, some of this work will be lost due to the conversion of mechanical energy into heat. Therefore, the integral of P with respect to V will always be greater than or equal to the work done by the system in the presence of friction.
b) In thermodynamics, a process function is a property that only depends on the initial and final states of the system, and not on the path taken to get there. Work is an example of a process function, as it only depends on the initial and final states of the system, regardless of the path taken to get there. Therefore, the work done by a system is always a process function.
c) The adiabatic work done by a closed system is independent of the process because it does not exchange heat with its surroundings. This means that the work done is solely determined by the initial and final states of the system, and not by the path taken to get there. Therefore, it is a process function.
d) In an expansion, the work done by the system is equal to the useful work (the work that is used to do something) plus the work done against friction (the work that is lost due to friction) plus the work done against atmospheric pressure (the work that is done to push against the surrounding air). Therefore, the statement that W_{expansion}=W_{useful}+\left|W_{friction}\right|+W_{atmospheric} is true.
FAQ: Thermodynamics: Work, True/False Questions
What is work in thermodynamics?
In thermodynamics, work refers to the transfer of energy from one system to another. It is typically measured in joules and can take on various forms, such as mechanical, electrical, or chemical work.
Is work always positive in thermodynamics?
No, work can be either positive or negative depending on the direction of energy transfer. If energy is transferred from the system to the surroundings, work is considered negative. If energy is transferred from the surroundings to the system, work is considered positive.
Can thermodynamics be used to explain the behavior of gases?
Yes, thermodynamics is commonly used to analyze the behavior of gases. The ideal gas law, which relates the pressure, volume, and temperature of a gas, is an example of a thermodynamic equation used to describe gas behavior.
Are all true/false questions in thermodynamics straightforward?
No, some true/false questions in thermodynamics may require critical thinking and application of concepts, rather than simple recall or memorization. It is important to thoroughly understand the concepts and principles of thermodynamics in order to accurately answer true/false questions.
Can thermodynamics be applied to everyday life?
Yes, thermodynamics has many practical applications in everyday life, such as in heating and cooling systems, refrigeration, and power generation. It also helps explain phenomena such as the transfer of heat and the behavior of engines and machines.
