nightingale
- 53
- 1
I did an experiment to measure air flow using a pitot static tube and a venturi meter.
First attempt: I connected both long and short manometers to the pitot static tube. Then I switch on the fan. The difference in manometer reading is 0.59kPa, which is the pressure. Then I found the volumetric flow rate to be 0.55386.
Second attempt: I connected both long and short manometers to the venturi meter. Then I switch on the fan. The difference in manometer reading is 1.24kPa, which is the pressure. Then I found the volumetric flow rate to be 0.34575.
What I don't understand is that, should theoretically the volumetric flow rate of both of them the same? Or it is supposed to be different? Why is it different? Thank you.
Pitot tube:
Q = a*vm
a = area of duct (duct diameter 0.15m)
vm = 1.291*sqrt Pv
Venturi Meter:
Q = Cd*a2 〖[2∆P/ {ρ(1-〖(a_2/a_1 )〗^2)}]〗^0.5
Cd= 0.98
d1= duct diameter 0.15m, a1= duct area
d2= Throat diameter (0.095) a2= throat area
ρ= 1.2 kg/m^3
Pitot-static tube:
vm = 1.291 √(P_v )
vm = 1.291 √(0.59×〖10〗^3 )
vm = 31.36 m2/s
Q = avm
Q = π/4×〖0.15〗^2×31.36
Q = 0.554 m3/s
Venturi meter:
Q = Cda2 〖[2∆P/ {ρ(1-〖(a_2/a_1 )〗^2)}]〗^0.5 (m3/s)
Q = 0.98 × π/4 ×〖0.095〗^2 〖[2×1.23×〖10〗^3/ {1.2(1-〖(〖0.095〗^2/〖0.15〗^2 )〗^2)}]〗^0.5
Q = 6.943×〖10〗^(-3) 〖[2460/(1.2 × 0.839)]〗^0.5
Q = 0.3436 m3/s
