johnsonc007
- 8
1. The problem at hand: A gas is contained in a closed rigid tank. An electric resistor in the tank transfers energy to the gas at a constant rate of 1000W. Heat transfer between the gas and the surroundings occurs at a rate of Q(dot) = -50t, where Q (dot) is in watts, and t is in time, minutes.
(a) Plot the time rate of change of energy of the gas for 0<t<20 min in watts. (actually t is greater than or equal to 0, and t is less than or equal to 20)
(b) Determine the net change in energy of the gas after 20 minutes, in kJ
2. I am not following on how to complete this task. I am confused by the Q(dot) equation. How can it equal watts when multiplied by minutes, as a watt is a J/s? Would get Q(dot)=Jmin/s...
3. I have tried to solve this numerous times, all with the wrong solution. I tried starting part b first as I need that data to do part a. I know that dE/dt = Q(dot) - W(dot). I drew two closed systems, one with the gas isolated with the resistor work entering and Q=0, and then another with the resister in the system and Q leaving the system, so that W=0. Am I on the right path? If so, what can I do with that? I found W=1200kJ but Q being some huge number and not working towards the correct solution.
Also took derivatives, but that got me nowhere fast too :(
