P111ltl
- 10
1. Homework Statement
Air at 20 degrees celsius and 100kpa is drawn into a wind tunnel. If the deflection h of a water manometer that is connected to a hole in the wall of the test section to measure the gauge pressure in the flow is 98mm. Calculate air speed in test section in m/s ignore fluid friction .
Take R of air to be 287 j/kgK and density of water to be 1000 kg/m3 and g= 9.81
part b) if the air speed is 45 m/s calculate the deflection h in the manometer.
2. Homework Equations
I have been having trouble with this for ages now and am really stuck have been looking at Pressure= density xg x height giving 961.38 Pa then using pv=nrt v=87.469 using this method unsure if I am barking up the wrong tree?
for part b) again using p=nRT/v = 1868.68 Pa then using P=densityxgxdelta h giving 190mm or 0.19m however this doesn't sound right to me as the 45 m/s air speed is causing a greater deflection that the previously worked out air speed so i am sure something is not quite right but what? I am converting 20 degrees to 293 K and using that any suggestion?
If anyone needs a drawing i will attempt one in paint.
Thanks very much in advance
