Thermosphere temperature paradox?
In summary, the high temperature in the thermosphere is due to the highly diluted gas, which can reach up to 2,500 °C during the daytime. However, due to the extremely low density of the gas, there is insufficient heat transfer, resulting in a cold sensation for an observer or object. This is because radiation is the only mechanism of heat transfer in this scenario, and the amount of heat lost through radiation can exceed the minimal heat gained by convection and conduction. Therefore, despite the high temperature, the thermosphere can still feel cold to an observer or object.
Molloy
This quote from Wikipedia says that temperatures in the Thermosphere can reach 2,500 C during the daytime but "despite the high temperature, an observer or object will experience cold temperatures".
"The highly diluted gas in this layer can reach 2,500 °C (4,530 °F) during the day. Despite the high temperature, an observer or object will experience cold temperatures in the thermosphere, because the extremely low density of gas (practically a hard vacuum) is insufficient for the molecules to conduct heat. "
How is it possible for the temperature to be 2,500 C but for the observer or object to feel cold?
If there is "insufficient density of gas", and it feels cold, doesn't that mean it's actually just cold?
Thanks.
Likes Merlin3189
Science news on Phys.org
There are three basic mechanisms of heat transfer: conduction, convection, and radiation. In a very dilute but hot gas it is possible to have very little heat transfer by conduction or convection. All of that small amount of heat transfer would of course be from the hot gas to the person, but the amount of heat would still be small.
But that still leaves radiation. If the person is in radiative contact with a cold object, such as deep space, then it is easily possible for the amount of heat lost through radiation to exceed the heat gained by convection and conduction. That would lead to the sensation of cold even in a very hot gas.
Likes Molloy
You need to understand the difference between temperature and heat. You can stick your hand in a 400 degree oven for a little while with no ill effect, but will be seriously injured if you dip it in a pot of boiling water at only 212 degrees. That's because the air in the oven has a higher temperature, but less heat.
The upper atmosphere is an extreme example of this: you have a very high temperature, but carrying very little heat. So little heat that it's insufficient to replace the heat that your body is radiating away.
Likes Dale, Molloy and davenn
Related to Thermosphere temperature paradox?
1. What is the Thermosphere temperature paradox?
The Thermosphere temperature paradox refers to the fact that the temperature in the uppermost layer of the Earth's atmosphere, known as the thermosphere, increases with altitude, which is the opposite of what would be expected based on the laws of thermodynamics.
2. What causes the Thermosphere temperature paradox?
The Thermosphere temperature paradox is caused by the absorption of high energy solar radiation by the gases in the thermosphere. These gases then transfer this energy to the surrounding air molecules, increasing their temperature.
3. How is the temperature in the Thermosphere measured?
The temperature in the Thermosphere is measured using instruments such as satellites, rockets, and ground-based radars. These instruments measure the infrared radiation emitted by the gases in the thermosphere, which can then be used to calculate the temperature.
4. Is the Thermosphere temperature paradox a recent phenomenon?
No, the Thermosphere temperature paradox has been observed for many years. However, with advancements in technology, scientists have been able to gather more data and gain a better understanding of this phenomenon.
5. What impact does the Thermosphere temperature paradox have on Earth?
The Thermosphere temperature paradox has a significant impact on Earth's weather and climate. The increased temperature in the thermosphere can affect the movement of air in the upper atmosphere, which can, in turn, impact weather patterns on Earth's surface.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
12K
