Thick walled pressurised cylinder
  • Thread starter Northyellow
  • Tags
    Cylinder
This will confirm the stress values calculated using the relevant equations, namely the Lame equations. In summary, the stress generated during operation of a cylinder on the festo rig at 60 bar pressure can be investigated by calculating the principal stresses on the cylinder surface using the Lame equations. These stress values can then be confirmed by measuring the principal strains using strain gauges.
Northyellow
1. Investigate the stress generated during the operation, at 60 bar pressure, of a cylinder on the festo rig.
i) calculate the principal stresses on the cylinder surface
ii) Use strain gauges to measure the principal strains and hence confirm the above stress value.
2. relevant equations: lame equations, 1. σ(r) = A - B/r^2
2. σ(Ѳ) = A+ B/r^2
3. Attempt at an answer
Inside radius 12.5mm
Outside radius 17mm
6x10^6 = a - b/r^2
0 = a +b/r^2
6x10^6 = a - b/0.0125^2
a = 6x10^6 + b/0.0125^2
0 = a + b/r^2
0 = 6x10^6 + b/0.0125^2 + b/0.017^2
-6x10^6 = b (1/0.0125^2 + 1/0.017^2)
-6x10^6 = b(9860.2)
b = -608.5
6x10^6 = a - (-)608.5/0.0125^2
6x10^6 - 608.5/0.0125^2 = a
a = 2105600
I do not understand, i am stupid :)
Principal stresses on the cylinder surface are σ(r) = 2105600 - 608.5/r^2 and σ(Ѳ) = 2105600 + 608.5/r^2.To measure the principal strains, strain gauges can be used. The strain gauges need to be attached to the cylinder surface and connected to a Wheatstone bridge circuit. The output voltage of the circuit can then be used to calculate the principal strains.
Related to Thick walled pressurised cylinder
1. What is a thick-walled pressurised cylinder?
A thick-walled pressurised cylinder is a type of container that is designed to hold pressurized fluids or gases. It is typically made of a strong material, such as steel, and has a thicker wall than a regular cylinder to withstand high levels of pressure.
2. What are the applications of thick-walled pressurised cylinders?
Thick-walled pressurised cylinders have a wide range of applications in various industries, including aerospace, automotive, and manufacturing. They are commonly used to store and transport compressed gases, such as oxygen, nitrogen, and carbon dioxide. They are also used in hydraulic systems and as pressure vessels for chemical reactions.
3. How is the pressure inside a thick-walled pressurised cylinder calculated?
The pressure inside a thick-walled pressurised cylinder can be calculated using the ideal gas law, which states that pressure is directly proportional to the number of moles of gas, the temperature, and the volume of the container. Additionally, the thickness and material of the cylinder must also be taken into consideration to determine its maximum pressure capacity.
4. What are the safety precautions for using thick-walled pressurised cylinders?
When working with thick-walled pressurised cylinders, it is important to follow proper safety precautions to avoid potential hazards. This includes wearing appropriate protective gear, such as goggles and gloves, and ensuring that the cylinder is properly secured to prevent it from tipping over. It is also important to regularly inspect the cylinder for any signs of damage or wear that could compromise its integrity.
5. How can thick-walled pressurised cylinders be tested for their strength and durability?
There are various methods for testing the strength and durability of thick-walled pressurised cylinders. These include hydrostatic testing, which involves filling the cylinder with water and pressurizing it to its maximum capacity, and ultrasonic testing, which uses sound waves to detect any defects or weaknesses in the cylinder's walls. These tests can help ensure the safe use of the cylinder and prevent potential accidents.
