Mark27
- 5
Hello.
1. vessel shall have minimum interval volume of 10m^3
2. outer diameter must less than 5m
3. radial elongation of vessel shall not more than 0.05% of diameter due to compression
variables:
Ro=Outer radius
Ri =Inner radius
r=radius at middle between outer and inner radius
ρm=density of material
v=poisson ratio
E=modulus of elasticity
σr= radial stress
σh=hoop stress
Because the pressure at 8000m is so high, I need to use thick walled formula.
i)So, in order to find minimum mass, the objective function is:
m= 4/3*pi*(Ro-Ri)*ρm
ii)Minimum internal volume:
10 ≤ 4/3*pi*(Ri^2)
iii)Maximum outer diameter:
2Ro ≤ 5
iv)von mises criterion (which i believe)
(σr^2)-(σr*σh)+(σh^2) ≤ (yieldstress^2)
v)radial deflection (which i believe)
r/E*[σr-vσh-vσr]≤ 0.05(2Ro)
So i believe the only problems right now are to find the equation for radial stress and hoop stress under external pressure only. Most references that I read only give equation for internal pressure only and internal & external pressure only. Thank you for your feedback.
