Thin film constructive vs destructive concept clarification
In summary, when light travels from vacuum to oil to water, the phase shift is 1/2 when it goes from air to oil and there is no phase shift when it goes from oil to water. To determine if there is constructive or destructive interference, you would add the two phase shifts together. Phase changes only occur when light reflects off of a medium with a higher index of refraction.
agentlee
So if light travels from vacuum to oil to water (1 -> 1.4 -> 1.33) how do you know if there is a constructive or destructive interference?
I know that when it goes from air to the oil there is a phase shift of 1/2. But when it goes from oil to water, there is no phase shift. How would you determine if the entire thing is constructive or destructive or not? Would you add the two phase shifts together to determine it?
If the light reflects from a medium with a higher index of refraction there is 180 deg phase change.
If the light reflects from a medium with lower index of refraction there is no phase change.
There is also no phase change from the light that is simply transmitted without reflecting, and this is true whether the light is traveling into a higher index of refraction or a lower index of refraction. Transmitted rays may have path length differences, but no phase changes.
Phase changes only happen on reflections, and only when reflecting off of a medium of higher index of refraction.
Related to Thin film constructive vs destructive concept clarification
1. What is the difference between thin film constructive and destructive interference?
Thin film constructive interference occurs when two or more waves of light are in phase and combine to produce a brighter, more intense light. In contrast, thin film destructive interference occurs when two or more waves of light are out of phase and cancel each other out, resulting in a dimmer or darker light.
2. How does the thickness of a thin film affect constructive and destructive interference?
The thickness of a thin film can determine whether constructive or destructive interference will occur. For constructive interference, the thickness of the film must be an integer multiple of the wavelength of the light. For destructive interference, the thickness must be a half-integer multiple of the wavelength.
3. What are some real-life applications of thin film constructive and destructive interference?
Thin film interference is commonly used in various optical devices, such as anti-reflective coatings on eyeglasses and camera lenses, thin film solar cells, and thin film coatings on computer and TV screens to enhance image quality.
4. How does the refractive index of a thin film affect constructive and destructive interference?
The refractive index of a thin film affects the phase difference between the waves of light and can impact the interference pattern. A higher refractive index can lead to a larger phase difference and greater constructive or destructive interference.
5. Can thin film interference occur with other types of waves besides light?
Yes, thin film interference can occur with other types of waves such as sound waves. However, the principles and equations used to calculate interference patterns may differ from those used for light waves.
