Thin film interference on water
In summary: Another way of looking at it: If the observer could see the light in the water from the side, he would see a different wavelength from what he sees if he looks at the light that has been reflected by the oil film. But he is looking at the light that has been reflected by the oil film. That light is no longer in water. It is in air. It has the wavelength in air.## \\ ## A third way of looking at it: What is important is the relative phase between the incoming light and the light that is reflected from the oil film. The medium doesn't change the relative phase. The light that reaches the observer has the same wavelength in air that it
Taniaz
364
An oil tanker spills a large amount of oil (n =1.47) into the sea (n = 1.33).
a) If you look down onto the oil spill from overhead, what predominant wavelength of light do you see at a point where the oil is 390 nm thick? What color is the light?
b) In the water transmitted under the slick, what visible wavelength (as measured in air) is predominant in the transmitted light at the same place in the slick as in part a?
c) If a diver below the water's surface shines a light up at the bottom of the oil film, at what wavelengths would there be constructive interference in the light that reflects back downward?
If anyone of the waves has a half cycle phase shift then for constructive interference 2t=(m+1/2)(wavelength).
I've done parts a and b and I know the equation for constructive interference will be the same as above as one of the waves going from water will have a half cycle phase shift but I'm not sure what wavelength they are asking for?Do they want the wavelength as seen in air?water?
In parts a and b I calculated the wavelength in air by substituting
wavelength in oil = wavelength in air / index of refraction of oil.
What did you get for parts ##a ## and ## b ##? I would be glad to check your calculations if you showed them.
Hi Chales, thank you for your reply.
I got the wavelength in air for part a to be around 458 nm. I used the constructive interference equation when one of the reflected waves has a half cycle phase shift 2t=(m+ 1/2)(lamda). I substituted lambda in oil = lambda in air / n using the equation (n1)(lambda 1)=(n2)(lambda 2)
For part b I got 573 nm and I used the destructive interference equation when one of the reflected waves has a half cycle phase shift so 2t=m(lambda). Because the question was asking for the wavelength in the visible range, only m=2 worked for both cases.
For part c, I'm not which wavelength the question is asking for, the wavelength in air or water? I know the equation will still be as in part a because one the reflected waves in water has a half cycle phase shift.
I agree with your answers to "a" and "b" . (And for part "a", it is the top surface that has the ## \pi ## phase shift for the reflected wave). ## \\ ## For "c" the wavelength he sees will be the wavelength in air. Even though he is under water, what he sees is related to the wavelength in air. They want the wavelength in air. He sees the light that reaches him. ## \\ ## One way of looking at it: The light that an observer sees is related to the frequency of the light. For an observer is really immaterial what medium the light travels through before it reaches him. The observer will see the wavelength that the light has in air. The medium doesn't change the frequency.
Related to Thin film interference on water
1. What is thin film interference on water?
Thin film interference on water is a phenomenon that occurs when light reflects off the surface of a thin film of water. As the light passes through the film, some of it is reflected and some of it is transmitted, resulting in a colorful interference pattern.
2. What causes thin film interference on water?
Thin film interference on water is caused by the difference in refractive index between air and water. When light travels from a medium with a higher refractive index (air) to a medium with a lower refractive index (water), some of the light is reflected and some is transmitted. This creates the interference pattern we see.
3. How does the thickness of the film affect the interference pattern?
The thickness of the film affects the interference pattern by changing the path length that the light travels through the film. As the thickness increases, the path length also increases, resulting in a shift in the interference pattern. This is why we see different colors at different thicknesses of the film.
4. Can thin film interference on water be observed in everyday life?
Yes, thin film interference on water can be observed in everyday life. It is commonly seen in soap bubbles, oil slicks on water, and even in the colors of certain bird feathers. It is also used in some technology, such as anti-reflection coatings on eyeglasses.
5. How does temperature affect thin film interference on water?
Temperature can affect thin film interference on water by changing the thickness of the film. As water evaporates, the film becomes thinner, resulting in a shift in the interference pattern. This can also affect the colors we see in the interference pattern. Additionally, changes in temperature can also affect the refractive index of water, further altering the interference pattern.
