404
- 52
There's two problems I can't seem to figure out...
and the other one is ...
I sort of got the answer, except I used m as 28 instead of 27. So my question is why are you suppose to use m as 27 to multiply instead of 28? Also What do they mean by incident normally, is it like striking the glass at a right angel?A fine metal foil separates one end of two pieces of optically flat glass. When light of wavelength 500nm is incident normally, 28 dark lines are observed (with one at each end). How thick is the foil? (answer = 6.75um)
A thin film of alcohol (n=1.36) lies on a flat glass plate (n=1.51). When monochromatic light, whose wavelength can be changed, is incident normally, the reflected light is a minimum for wavelength = 512nm, and wavelength = 640nm. What is the thickness of the film? (answer = 471nm)
