Thin Film Interference Question
In summary, this conversation discusses the use of a thin film sandwiched between two materials to produce fully constructive interference at an observer above the film. The film has a thickness of 5.24*10^-7 m and the indexes of refraction for the top, film, and bottom layers are 1.80, 1.68, and 1.50 respectively. The conversation also includes equations for constructive and destructive interference and a question about finding the longer and shorter wavelengths that result in constructive interference. The wavelength in the formula is the wavelength in the film, and the indices decrease as you go down through the layers, potentially causing a phase change.
ChibiMolinero
White light is sent downward onto a horizontal thin film that is sandwiched between two materials. The indexes of refraction are 1.80 for the top material, 1.68 for the thin film, and 1.50 for the bottom material. The film thickness is 5.24*10^-7 m.
(a) Of the visible wavelengths (400 to 700 nm) that result in fully constructive interference at an observer above the film, which is the longer wavelength?
(b) Which is the shorter wavelength?
2t = mλ/n - for constructive interference
2t = (m+.5)λ/n - for destructive interference
I don't even know where to start. I'm not sure if the wave goes through air before hitting the top layer, or if that's even relevant? I don't know if they're looking for the wavelength in air? If I have to use the wavelength in the film to find the wavelength in the top layer to find the answer? Any help would be greatly appreciated.
Welcome to PF, Chibi.
The λ/n in the formula is the wavelength in the film, where λ alone is the wavelength in vacuum. Your answers will be values of λ.
The indices decrease as you go down through the 3 layers; this is opposite to the usual situation where the top layer is air. It seems to me this will cause a phase change that will change the formula. Might be worth looking into.
Related to Thin Film Interference Question
What is thin film interference?
Thin film interference is a phenomenon that occurs when light reflects off of a thin layer of a medium, resulting in constructive and destructive interference. This creates a pattern of light and dark fringes, known as interference fringes, which can be seen when white light is shone onto the film.
How does thin film interference occur?
Thin film interference occurs when light waves reflect off the top and bottom surfaces of a thin film, such as a soap bubble or a layer of oil on water. These waves interfere with each other, either constructively or destructively, depending on the thickness of the film and the wavelength of the light.
What factors affect thin film interference?
The thickness of the film, the refractive index of the film and surrounding medium, and the angle of incidence of the light are all factors that can affect thin film interference. The wavelength of the light and the type of film material can also play a role in the interference pattern.
What are some real-life applications of thin film interference?
Thin film interference is used in a variety of technologies, such as anti-reflective coatings on glasses and camera lenses, thin film solar cells, and optical filters. It is also used in scientific research to study the properties of materials and to analyze the thickness of thin films.
What is the difference between thin film interference and Newton's rings?
Thin film interference and Newton's rings are both examples of interference patterns, but they occur in different situations. Thin film interference occurs when light reflects off a thin layer of a medium, while Newton's rings occur when light passes between two curved surfaces, such as a lens and a flat glass plate. Additionally, the interference fringes in thin film interference are parallel, while they are circular in Newton's rings.
