Thin Film Interference- Transmission
In summary, the water layer will not transmit light through it at the point where the layer is 113 nm thick.
jayjay713
25
A thin layer of water (n=1.33) is surrounded by air what wavelength of light will not be transmitted through the water at the point where the water is 113 nm thick?
- In phase
- Path difference of 2T.
- Constructive Interference
I just don't know how to set up the formula to find the wavelength. I know to find the wavelength in water I divide wavelenght in air by the index of refraction of water.
Any help appreciated, cheers.
Are you certain the question asks for light not TRANSMITTED. ?
yes! The answer is 601 nm.
If you take the wavelength and times it by the index of refraction of water (1.33), you get 150.29. Multiply that by 4 and get ~601 nm. Don't know how that fits into the formula of 2T = wavelength / something (in example its over 4 or 2, don't know how to get that value)
there is some confusion here.
The wavelength of light in water is shorter than in air =λair/1.33
For the transmittance of a thin layer surrounded by air, the condition for destructive interference is 2Tn=(m+1/2)lambda. The transmittance is minimum at λ=601 nm but it is not zero. The reflectance can be zero because of destructive interference, the transmittance cannot.
ehild
It is not a weird total internal reflection question... is it?
I agree with ehild ...there will always be some transmission... mostly transmission.
It is possible to get no reflection as a result of interference but this requires some reflection from the air/water and water/air boundaries. This is never 100% (unless it involves total internal reflection)
Look forward to hearing more posts on this one.
It is a weird thin layer interference question. The maker of the problem might think that all destructive interference is totally destructive.
At constructive interference,the maximum transmittance of a stand-alone thin layer is 100% (ignoring the slight absorption), but the minimum transmittance at destructive interference depends on the refractive index both of the layer and of the surrounding medium. If the refractive index of the ambient is n0 and that of the layer is n1, the minimum transmittance is 4n02n12/(n02+n12)2, about 92% for the water layer.
ehild
Related to Thin Film Interference- Transmission
1. What is thin film interference?
Thin film interference is a phenomenon that occurs when light passes through a thin film or layer of material, resulting in interference patterns and changes in the color or brightness of the transmitted light. The interference is caused by the reflection and transmission of light waves at the boundaries of the thin film.
2. How does thin film interference affect the color of objects?
Thin film interference can cause objects to appear to have different colors due to the way light reflects and transmits through the thin film. Depending on the thickness of the film and the angle at which the light enters, certain wavelengths of light will be amplified or canceled out, resulting in a change in color.
3. What factors affect thin film interference?
The thickness of the film, the angle of incident light, and the refractive index of the materials involved are the main factors that affect thin film interference. These factors determine the path and phase difference of the light waves, which ultimately impact the interference pattern and the resulting colors.
4. How is thin film interference used in everyday life?
Thin film interference is used in a variety of everyday products, such as anti-reflective coatings on eyeglasses, anti-glare coatings on screens, and iridescent surfaces on CDs and DVDs. It is also used in industrial settings for quality control of coatings and in electronic devices such as thin film solar cells and LCD displays.
5. What is the difference between thin film interference and Newton's rings interference?
Thin film interference occurs when light passes through a thin film, while Newton's rings interference occurs when light is reflected off of a curved surface. In thin film interference, the thickness of the film determines the interference pattern, while in Newton's rings interference, the curvature of the surface is the determining factor.
