CptXray
- 23
- 3
There's a thin, straight, infinite wire conducting alternating current:
$$I(t) = I_{0}\exp(-\kappa t^2),$$
where ##\kappa > 0##.
Calculate the force exerted on point charge ##q## that is located in distance ##\rho## from the wire. Consider relativistic effects.
Ampere's law:
$$\int\limits_{\partial V} \vec{B} \vec{\mathrm{d}l} = \int \limits_{V} \vec{j} \vec{\mathrm{d} s}$$
$$\nabla \times \vec{E} = - \frac{\partial{\vec{B}}}{\partial{t}}$$
First, the magnetic field of a straight infinite wire:
Using Ampere's law, where ##\partial{V}## is a circle, centered on the wire:
$$B_{\phi} 2 \pi r = \mu_{0} I$$
$$B_{\phi} = \frac{\mu_{0}I}{2\pi} \frac{1}{r} \hat{\phi},$$
where ##B_{\phi}## is a magnetic field in azimuthal direction and ##r## is the distance from the wire.
Now, I know that the magnetic field is changing with time:
$$- \frac{\partial{B_{\phi}}}{\partial{t}} = 2kt\frac{\mu_{0} I}{2\pi}\frac{1}{r} \hat{\phi}$$
I tried doing double curl ##\nabla \times (\nabla \times \vec{B}) = \nabla (\nabla \cdot \vec{E}) - \Delta E##, but I have a feeling that it gets me nowhere.
