- #36
sysprog
- 2,617
- 1,796
I was about to reply to your post while I thought that it consisted of only its first sentence ##-## when I hit the Reply button, I got (presumably) the rest of the post ##-## here's a screen shot of the anomaly:
Perhaps @berkeman will take note.
Anyway, onward to the reply:
I would call the time limit the infinitesimal instead of calling it zero. The distance from a point to itself is zero; the distance from any point in a continuum to 'the nearest point therein that is not the same point' (a point that does not exist in the reals) is positive, and therefore is non-zero. In my view, the shortest possible existent duration or distance is infinitesimal, not zero, A single point has zero distance, because it is not an interval, but it has non-zero, infinitesimal size, because it occupies a location, and I regard an instant as having infinitesimal non-zero magnitude, wherefore I think that it is misleading to say that it has zero duration.jbriggs444 said:A velocity is the limit of the ratio of a directed distance over a duration as the duration and distance approach zero. It is a limit, not a ratio.
I agree regarding the transfer principle, and disagree that it does not help, although I think that it does not suffice. Also necessary are the acceptance of incompleteness and the denial of the excluded middle axiom.If you are careful, you can use the transfer principle to turn this statement about velocity in the reals as a limit into a statement about a velocity in the reals as a ratio of infinitesimals. But that does not help make the point you need to be trying to make.
I think that only the empty set should be said to have measure zero. I know that standard measure theory is less impromiscuous than that regarding its use of the term 'zero'. I am not so much griping about the mathematics as I am deploring what I regard to be the misuses of the term 'zero' ##-## when I brought this up in school, I was told that I could use such substitutes as 'treated as zero', or 'negligibly different from zero', if I wanted to eschew using 'zero' for infinitesimals. I agree that velocity is the first derivative of position wrt time, the second being acceleration (that can be problematic regarding direction), the third being 'jerk', and the fourth being 'jounce' or 'snap', and when I am doing derivatives, I use delta epsilon limits just like everyone else, but when saying things about them, I don't speak or write as if the infinitesimal were exactly equal to zero.The set of points where velocity is zero is a degenerate interval consisting of a single point. The measure of that set is zero.
