MHB Thinking about the Definition of a Unit of a ring R .... ....
Math Amateur
MHB
I have been thinking around the definition of a unit in a ring and trying to fully understand why the definition is the way it is ... ...
Marlow Anderson and Todd Feil, in their book "A First Course in Abstract Algebra: Rings, Groups and Fields (Second Edition), introduce units in a ring with 1 in the following way ... ...
https://www.physicsforums.com/attachments/6402
So ... an element $$a$$ of a ring $$R$$ with $$1$$ is a unit if there is an element $$b$$ of $$R$$ such that
$$ab = ba = 1$$ ... ... So ... if, in the case where $$R$$ was noncommutative, $$ab = 1$$ and $$ba \neq 1$$ then $$a$$ would not be a unit ... is that right?Presumably it is not 'useful' to describe $$a$$ as a 'left unit' in such a case ... that is, presumably, one-sided units are not worth defining ... is that right?
Could someone please comment on and perhaps clarify/correct the above ...Hope someone can help ...
Peter
Hi Peter,
Yes, that's correct.
No. The common terms are 'left inverse' and 'right inverse'. These concepts are useful, and you have already encountered them. As an example, let $R$ be the ring of linear transformations on $\mathcal{l}^1(\Bbb C)$, the space of summable complex sequences. The shift operators $S : (a_1,a_2,a_3,\ldots) \mapsto (a_2,a_3,a_4,\ldots)$ and $T : (a_1,a_2,a_3,\ldots) \mapsto (0,a_1,a_2,\ldots)$ are elements of $R$ that satisfy $ST = \operatorname{id}$ (so then $T$ is a right-inverse for $S$ and $S$ is a left-inverse for $T$), but $S$ and $T$ are not units in $R$.
Euge said:
Hi Peter,
Thanks for the help, Euge ...
Appreciate your assistance ...
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
