Thinking about the static electric field in terms of QFT
In summary, according to classical electrodynamics, an electron's electric field is a physical entity that has momentum. When a test charge is placed near the electron, it is affected by the electric field, not the electron itself. In contrast, according to QFT, charge is created when the electron field and the electromagnetic field oscillate due to inputting energy. The electron particle is an excitation of the electron field, but the excitation of the electromagnetic field is usually referred to as a photon. The static electric "field" of the electron is not a state of the electron field, but rather a state of the electromagnetic field. This field is not continuous like the classical image of it, but rather can be thought of as a collection
FallenApple
566
61
So according to classical electrodynamics, an electron would produce an electric field that is a physical entity in and of itself. This field has momentum so when a test charge is placed within this vicinity, it would be affected by the field itself, not the electron.
But what about the QFT way of looking at it? I've heard that charge is created when the electron field and the electro magnetic field oscillate due to inputing energy. And that this charge happens at a contour of the energy function where the strength of the em field and the electron field are the inputs of the energy function.
So the electron particle is an excitation of the electron field, but what about the excitation of the electromagnetic field? Where does that manifest itself? Is it the static electric field that we always see? But then wouldn't that static "field" then be made of particles since it too is an excitation?
So would the static electric "field" of the electron not be the lowest state of fundamental field itself but an excitation of it? So then it isn't a continuous field per se like the classical image of it.
I've wondered a similar thing...
It seems as if the constancy of c was originally attributed to a absolute universal undetectable "static field", then updated by the allocation of individual undetectable "static fields" to frames of reference with constancy of c.
It also seems that originally electrons were allocated individual fields, then updated to a universal electron field within which local excitation represents electrons.
Looks like relativity went one way denying any absolute universal "static fields"... not sure if QFT consider themselves going the other way...?
Please give a specific reference. This doesn't look right.
Yes.
That's usually called a photon. However, not all field states can be usefully decribed as "excitations" in this sense; i.e., not all field states can be usefully thought of as "particle" states.
No. A static electric field is one of those field states that can't be usefully thought of as a "particle" state.
Is not a state of the electron field. It's a state of the electromagnetic field (the one whose "particle" states are called photons).
The electron field, since it is a fermion field, does not have a "classical" counterpart. Only boson fields, like the electromagnetic field, have classical counterparts.
I don't know where you're getting this from. The constancy of c came from measurements of electromagnetic waves, which are not static.
I don't know where you're getting this from either. Prior to QFT electrons were just thought of as particles; there was no field associated with them.
I think he explains it around 9:00 min. He draws a parabolid where the z axis is energy and the x and y-axis are fields. The contour is a circle which means the fields have to change value as one transverses it.
This has nothing to do with "creating charge". Charge is an inherent property of a field; more precisely, it's an inherent property of an interaction between fields--in the specific case of electric charge, it's the coupling constant of the interaction between the electromagnetic field and other fields (it can be different for different fields, since different fields can have different charges, but for any given field it's a constant).
No. What he's talking about here is a way of visualizing how oscillations in a field can "look like" particles. Basically, if the value of the field is at the bottom of the paraboloid, the field is in its ground state, also called the "vacuum" state, because in this state there are zero particles. But if the value of the field is somewhere up on the side of the paraboloid, then it is not in the ground state and you can (sometimes) view the state as a "particle". If the field has a charge (i.e., a coupling constant for interacting with the electromagnetic field), then the particle will be a charged particle; but the fact that the field's value in a "particle" state might be changing (for example, if the field's value is moving around in a circle at a constant "altitude" on the paraboloid, as Susskind describes it doing in a state of constant angular momentum) does not mean the charge (the coupling constant of the interaction with the electromagnetic field) is changing.
What do you mean by we can sometimes see it as a particle? I thought particles are excitations in fields. So an excitation in fields can lead to other things besides particles? Would that be where the classical field comes from?
So the charge is the coupling constant and as a constant it doesn't change. So then if I have a charge at the value of energy E, then the charge can be of any combination of the EM field and the electron field? So basically there is no physical angular momentum since the view of the parabolid doesn't treat the horizontal variables as being parameterized by time.
Yes.
So the static field is not a particle state and yet it has a strength so it is not of 0 value. I thought when fields reach non 0 values in QFT, we see particles.
So the electromagnetic field has a classical counterpart because it is made of bosons? Is it because of the pauli exclusion principle? Can I view the EM field as being made of descretized packets that can overlap smoothly to make a field because the pauli exclusion principle allows it?
Yes, but not all states of quantum fields have a useful particle interpretation.
The word "excitation" is usually used in connection with field states that have useful particle interpretations. But that's a matter of language, not physics. The physics, as I said before, is that not all quantum field states have useful particle interpretations. Quantum field states corresponding to classical static fields are among the states that don't have useful particle interpretations.
Likes FallenApple
That is not correct. See my previous comments.
Because it is a bosonic field. That is not the same as being "made of bosons", because the latter language implies a particle interpretation, which, as I've said, states corresponding to classical static fields do not have.
No. The Pauli exclusion principle only applies to fermions (or fermion fields, more generally).
No. See above.
Related to Thinking about the static electric field in terms of QFT
1. What is QFT (Quantum Field Theory)?
QFT is a theoretical framework used to describe the behavior of particles at the quantum level. It combines principles from quantum mechanics and special relativity to explain the fundamental interactions between particles.
2. How does QFT explain the static electric field?
In QFT, the static electric field is described as a quantum field that is created by the presence of charged particles. These particles interact with the field, which in turn affects their behavior and movement.
3. What is the role of virtual particles in QFT?
Virtual particles are an essential concept in QFT. They are particles that are not directly observable, but their presence is necessary to explain the behavior of particles and fields at the quantum level.
4. How does QFT differ from classical electromagnetism?
Classical electromagnetism describes the behavior of electric and magnetic fields at a macroscopic level, while QFT explains their behavior at the quantum level. QFT takes into account the uncertainty principle and the existence of virtual particles, whereas classical electromagnetism does not.
5. What are the practical applications of QFT?
QFT has many practical applications in fields such as particle physics, condensed matter physics, and cosmology. It is used to understand and predict the behavior of particles and fields at the smallest scales, leading to advancements in technology and scientific understanding.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
