- 9,832
- 4,895
Following is a conversation that was started by a fellow tinkering with a MOT
which can be very dangerous
but to his credit he DID remove the deadly high voltage winding(at least he said he did).
It belongs in a thread
so I'm moving it here
I assume he's removed not only the secondary winding
but the top of the core as well
leaving the magnetic circuit 2/3 iron 1/3 air.
Mr Shantanu
What is it you want to make?
Have you looked up the equations for Inductive Reactance, Xl=2pifL
and inductance L ?
What is it you have done?
Take a photo with your phone, email it to yourself, clean it up with Paint, and use the upload button.
It is rude to ask us to guess .
old jim
- https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108278
shantanu23
Hi,
Case 1:
I took out the secondary winding of a microwave transformer and kept the Primary winding in the transformer core. Now when i Connect the primary winding to the mains (220V) AC supply. the fuse blows.
Case 2:
But when I connect a 50watt electric bulb to the circuit in series to the coil the circuit is closed and works fine but NO ELECTROMAGNET gets created here.
Why doesn't the Case 1 work. Isnt the inductive resistance created by the Primary winding enough. What can i do so that I am able to produce Electromagnet along with a 220V Ac Supply.
Please help.
Regards,
shantanu23, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108278 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108278
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108278 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108281
The Electrician
shantanu23 said: https://www.physicsforums.com/goto/convMessage?id=108278#convMessage-108278
Hi,
Case 1:
Case 2:
Please help.
Regards,
Post a thread in the Electrical Engineering forum: https://www.physicsforums.com/forums/electrical-engineering.102/
asking your question. Post a picture there of the transformer as it looks now that you have removed the secondary.
The Electrician, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108281 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108281
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108281 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108409
jim hardy
https://www.physicsforums.com/account/upgrades
i agree with Mr Electrician post it on the thread.
Sounds to me like one of two things:
1. the primary winding is damaged
2. you removed the wrong wimding and are applying line voltage to the 2 volt coil(big wires) that's intended to power the magnetron's heater
We need to see what it is that we're asked to diagnose.
"Never trust a computer with anything important."
jim hardy, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108409 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108409
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108409 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108423
The Electrician
jim hardy said: https://www.physicsforums.com/goto/convMessage?id=108409#convMessage-108409
He says "No electromagnet gets created here". ?
How does one create an electromagnet out of a microwave oven transformer? Or any transformer, for that matter?
A transformer has a closed magnetic path, but an electromagnet needs an open magnetic path. One might disassemble a standard transformer with E and I laminations. restack it without the I lams, and have the ends of the E lams just open. Then you would have an "electromagnet". Now imagine what would happen if you apply rated AC voltage to the primary! Blown fuse.
I'm concerned that he may have done something like that, trying to make an "electromagnet".
The Electrician, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108423 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108423
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108423 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108432
shantanu23
The Electrician said: https://www.physicsforums.com/goto/convMessage?id=108423#convMessage-108423
shantanu23, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108432 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108432
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108432 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108433
shantanu23
Thats right @The Electrician.
I removed the I laminations from the microwave transformer and kept the Primary Winding in the E laminations of the microwave transformer.
@jim hardy...I am using the Primary Winding in the 'E' laminations of the microwave transformer core. And when i connect it to the 220 Volt AC mains there must be an INDUCTIVE resistance in the coil to check the current being drawn, which in turn should not allow the fuse to be blown. With a bulb in series the fuse doesn't blows but at the same time no electromagnet gets created.
Is there some thing that i am missing...please guide.
shantanu23, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108433 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108433
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108433 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108436
The Electrician
shantanu23 said: https://www.physicsforums.com/goto/convMessage?id=108433#convMessage-108433
It's only when the I lams are in place that the inductive reactance is sufficient to prevent the fuse from blowing. I have to leave home for a while, so I'll let Jim Hardy explain more.
The Electrician, https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108436 https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/report?message_id=108436
https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/reply?m=108436 - https://www.physicsforums.com/conversations/transformer-getting-short-circuited.78710/message?message_id=108437
shantanu23
Yes that's right @The Electrician... so how can i create an electromagnet with only E Lams with the primary winding...is there any way to do that with 220 volts AC...thats where I am stuck...Please guide.
Mr Shantanu
and inductance L ?
old jim
