MHB This isn't even funny how hard it is
  • Thread starter Thread starter gilamonster
    even Funny Hard
The discussion focuses on calculating the total surface area of a cylinder using the formula A = 2πr² + 2πrh. Given the radius r = (4x + 2)/2 and height h = 2x, the equation is set equal to 182π to solve for x. After substituting r and h into the surface area formula, the resulting quadratic equation 16x² + 12x - 181 = 0 is derived. The participants discuss solving this quadratic to find the value of x, which is then used to determine the diameter of the cylinder. The calculations emphasize the importance of correctly applying geometric formulas in problem-solving.
Mathematics news on Phys.org
total surface area of a cylinder, $A = 2\pi r^2 + 2\pi rh$
from the sketch, $r = \dfrac{4x+2}{2}$ and $h=2x$
substitute for $r$ and $h$ and set equal to $182\pi$, solve for $x$, then determine the diameter
That's pretty straight forward. The diameter is 4x+ 2 so the radius is 2x+ 1. The top and bottom each have area $\pi r^2= \pi (2x+ 1)^2$. That totals $2\pi(2x+ 1)^2$. For the side, imagine cutting down the side and "unrolling" it. You get a rectangle with width 2x and length equal to the circumferce of the circles $2\pi r= \pi(4x+ 2)$, That area is $\pi(8x^2+ 4x)$ so the total area is $2\pi(2x+ 1)^2+ \pi(8x^2+4x)= \pi(8x^2+ 8x+ 1+ 8x^2+ 4x)= \pi(16x^2+ 12c+ 1)= 182\pi$.
Dividing both sides by $\pi$, $16x^2+12x+ 1= 182$. Subtracting 182 from both sides, $16x^2+ 12x- 181= 0$. Solve that quadratic equation for x.
$2\pi (2x+1)^2 + \pi(8x^3+4x) = \pi(8x^2+8x + {\color{red}2} +8x^2+4x)$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
