This juggler problem drining me crazy
  • Thread starter Alpharup
In summary, the problem is asking for the number of balls moving upward at one instant while a juggler throws balls with equal speed and releases a ball when the previous one has reached maximum height. To solve this, we can use the equation of motion to calculate the maximum height attained by the first ball, and then use the time interval between release of two balls to determine the number of balls moving upward at one instant. The second equation provided in the conversation is incorrect and should not be used.
Alpharup
225
A juggler throws balls up with wqual speed. He releases a ball when the previous pne has reached maximum height. the number of balls moving in the upward direction at one instant is
[a]1 2 [c]3 [d]4
Let the velocity of the balls thrown be 'u'. Let the maximum height that the balls reach be 'h'. Let the time difference between release of two balls be 't'. let the time to reach the maximum height be 'T'
h=uT-[1/2]gT^2
[h/2]=ut-[1/2]gt^2
sharan swarup said:
h=uT-[1/2]gT^2
[h/2]=ut-[1/2]gt^2
I agree with the first equation. But how did you get the second one? The first ball has reached a height h before the second ball is released, not h/2.
Try it without equations. Draw diagrams of what's happening.
sharan swarup said:
A juggler throws balls up with equal speed. He releases a ball when the previous one has reached maximum height. the number of balls moving in the upward direction at one instant is
[a]1 2 [c]3 [d]4
h=uT-[1/2]gT^2
[h/2]=ut-[1/2]gt^2
Ok , let's move step by step.
Let he throw a ball at u velocity as you mentioned. Then what is the maximum height attained by that ball ? Use this equation of motion :
h= 1/2t(v+u)
Now what is the time interval when that ball has reached its height h ? t right ? Then what will be the time interval between that ball attaining h height and release of another ball ?
[Your second equation is absurd I think. How did you get it ?]
t^2-2uT+2h/g=0
t= [2uT+sqrt(4u^2T^2-8gh)]/2
t=uT+sqrt(u^2T^2-2gh)
t=uT+sqrt(0)
t=uT
Since the time difference between release of two balls is equal to the time taken for a ball to reach maximum height, the number of balls moving in the upward direction at one instant will always be 1. Therefore, the correct answer is [a]1.
I would also like to mention that this problem can be solved using the equations of motion and the concept of projectile motion. The number of balls moving in the upward direction at one instant can also be determined by analyzing the velocity and acceleration of the balls at different points in time. I would suggest practicing more problems on projectile motion to gain a better understanding of this concept.
FAQ: This juggler problem drining me crazy
What is the juggler problem?
The juggler problem is a mathematical puzzle that involves a juggler who is trying to juggle a certain number of balls. The number of balls increases by one with each toss, and the juggler must catch all of the balls and start over with the original number of balls. The puzzle asks how many tosses it will take for the juggler to return to the original number of balls without dropping any.
What is the formula for solving the juggler problem?
The formula for solving the juggler problem is n(n+1)/2, where n is the original number of balls. This formula gives the number of tosses needed for the juggler to return to the original number of balls without dropping any.
What are some strategies for solving the juggler problem?
One strategy for solving the juggler problem is to create a table or chart and write out the number of balls and tosses for each step. This can help to identify patterns and make it easier to find the answer. Another strategy is to start with smaller numbers and work your way up, using the formula to check your answers.
Are there any real-life applications for the juggler problem?
The juggler problem is a purely mathematical puzzle and does not have any direct real-life applications. However, it can help to develop problem-solving skills and logical thinking, which are important in many fields of science and beyond.
What is the difference between the juggler problem and the Josephus problem?
The juggler problem and the Josephus problem are similar puzzles, but they have different rules. In the Josephus problem, a group of people stand in a circle and every second person is eliminated until only one remains. In the juggler problem, the juggler starts with a certain number of balls and must return to that number without dropping any, while in the Josephus problem, the last person standing is the survivor.
