This log problem is throwing me off, out of nowhere
  • Thread starter Jurrasic
  • Tags
    Log
In summary: I hope OP can simplify \displaystyle e^{\ln(x+1)}\text{ and ...}e^{\ln(x-1)}\) to get the desired result.
Jurrasic
98
Question is: solve for x
ln(x+1)-1 = ln(x-1)
tried to do it TWO different ways, and neither is the right way, check this out:
first attempt:
since LN is on both sides , it goes away and you just have variables, that way sucks because then you get 0=-1 , wrong.
second attempt:
divide both sides by ln(x+1)
that leaves -1 on one side and a bunch of nonsensical stuff on the other side.
WHAT TO DO?
Think about the formula ln(a)-ln(b) = ln(a/b) :wink:
ln(x+1)-1 = ln(x-1)
Your first assumption was not correct. Yet your subsequent reasoning was logical and you yourself noticed that the conclusion did not make sense.
You do not have ln(...) = In(...)
but you have In(...) + 1 = In(...).
Follow the advice of Mentallic.
Thats exactly what is above where the answer is wrong , where you get -1 on one side
already did that and the answer was wrong, see above. answers not needed, but steps and how to
-1=ln(x-1)-ln(x+1).
Now try applying what Mentallic said. :wink:
Is this what you're referring to?
Jurrasic said:
first attempt:
[tex]\ln\left(x+1\right)\neq \ln\left(x-1\right)[/tex]
so you can't just take away the ln(...) from both sides to get 0=-1, use the formula I suggested and try again.
ln(x+1)-1 = ln(x-1)
first attempt:
second attempt:
WHAT TO DO?
You can use each side of the equation,
ln(x+1)-1 = ln(x-1)​
as an exponent with a base of e.
[itex]\displaystyle e^{(\ln(x+1)-1)}=e^{\ln(x-1)}[/itex]
See what you can do with that.
Alternatively, it might be simpler to write the first equation above as
[itex]ln(x + 1) - ln(x - 1) = 1[/itex]
and then use a property of logs to write the left side as ln of a single expression. Then exponentiate both sides.
and then use a property of logs to write the left side as ln of a single expression. Then exponentials both sides.
Yes, Mark, I agree, but OP seemed to be unable to do this.
But I"m failing to see how I could do anything with your suggestion other than to go back to where the question started. Can I get a hint? :smile:
The simplest way to do it is to get it in the form
In(x + 1) - In(x -1) = 1
and then use In(a) - In(b) = In(a/b) as the other posters suggested.
There is no "In" function. It is ln (ell en), an abbreviation for natural logarithm (logarithm naturalis, in Latin).
Have I been asked what this suggestion was good for?
is equivalent to:
[itex]\displaystyle e^{\ln(x+1)}e^{-1}=e^{\ln(x-1)}[/itex]
I hope OP can simplify [itex]\displaystyle e^{\ln(x+1)}\text{ and }e^{\ln(x-1)}[/itex]
FAQ: This log problem is throwing me off, out of nowhere
What is the log problem and why is it throwing me off?
The log problem refers to a mathematical equation or function that involves taking the logarithm of a number. This can be confusing because it is a non-intuitive concept for many people. It may be throwing you off because you may not have a strong understanding of logarithms and their properties.
How can I improve my understanding of logarithms and solve this problem?
One way to improve your understanding of logarithms is to review the basic definition and properties of logarithms. You can also practice solving different types of log problems to become more comfortable with the concept. Additionally, seeking help from a tutor or teacher can also be beneficial.
Is it possible to solve the log problem without using a calculator?
Yes, it is possible to solve log problems without using a calculator. However, it may be more challenging and time-consuming. It is important to have a strong understanding of logarithms and their properties in order to solve them by hand.
Why is it important to know how to solve log problems?
Logarithms are used in many fields of science, such as chemistry, physics, and biology. They are also commonly used in finance and engineering. Understanding how to solve log problems is important for making accurate calculations and solving real-world problems.
What are some common mistakes to avoid when solving log problems?
Some common mistakes when solving log problems include forgetting to apply the properties of logarithms, using the wrong base for the logarithm, and making calculation errors. It is important to double-check your work and be familiar with the properties of logarithms to avoid these mistakes.
