- #36
BicycleTree
- 520
For example, if you wanted to throw it back up in a third the time it spends in the air, you would have to exert four times as much force as it weighs.
The necessary force is just a smidge more than the weight of the ball and in that case, the time spent accelerating the ball would be roughly equal to the time that it spends in the air. You are correct that this is not the normal way to juggle, but that was not a condition of the puzzle.BicycleTree said:And normally when juggling you would accelerate the falling ball to its original vertical velocity in much less time than it spends in the air.
jimmysnyder said:The necessary force is just a smidge more than the weight of the ball and in that case, the time spent accelerating the ball would be roughly equal to the time that it spends in the air. You are correct that this is not the normal way to juggle, but that was not a condition of the puzzle.
By the way, there is no way to juggle the balls without accelerating your own fingers, or some part of your own body. Also, you need to overcome air resistance on the ball. In short, you will actually increase the downward force on the bridge by juggling. You would be better off just carrying the balls and hoping for the best.
This is an extremely unfair description of the generous efforts of several people to explain those laws to you. Once again, if you juggle with small force, you will need to have two balls in your hands at the same time. If you juggle with enough speed so you can hold one at a time, you will need more force. If you insist that Newton's laws don't apply because you don't understand them, then you are going to be all wet.Huckleberry said:Just saying it is impossible according to Newton's laws doesn't explain to me why it is impossible.
Huckleberry said:If he only handles one ball at a time then when he throws one ball he will have the full 5lbs to deal with the next. Is 5lbs of force enough to arrest the motion of a 2 lb ball and provide a small lift to counter gravity? At what point in this process does he go over 5 lbs?
Yes--I hadn't considered the inertia of your own arms.jimmysnyder said:The necessary force is just a smidge more than the weight of the ball and in that case, the time spent accelerating the ball would be roughly equal to the time that it spends in the air. You are correct that this is not the normal way to juggle, but that was not a condition of the puzzle.
whozum said:The amount of force you need depends on how high you initially threw the ball in the first place.
BicycleTree said:No, you could theoretically throw the ball three miles into the air using only 5 pounds of force on each throw. The height does not matter for the force; only the proportion of time in the air or in your hand matters.
If you exert a force exactly equal to the weight of the ball, then there will be no net force on the ball and it will move with constant velocity. A smidge more and it will accelerate upward.BicycleTree said:As I said, you would need to exert force equal to twice the weight of the ball.
Now you have twisted my words.Huckleberry said:I don't think they were unfair questions.
Private praise and public apologies.jimmysnyder said:Now you have twisted my words.
I hope that you will accept my apologies and we can go on without any hard feelings. I am sorry.Huckleberry said:I don't think they were unfair questions.
Greg825 said:more nitpicking :) : I don't think this is (directly) so, increasing the height increases the time allowed to accelerate the ball back upward. I showed In my proof that time cancels and height is irrelavent (this was assuming the maximum amount of time was used to accelerate a ball). What really effects the force you need is the impulse you apply, which is dependant on time spent accelerating the balls upward.
whozum said:Thats pretty much exactly what I said, The force you need to apply must be greater than the impulse of the ball's impact and the impulse to get rid of it again.
whozum said:I don't tihnk this is so at all. Regardless of how high the person threw it, assuming it is not along the magnitude of his maximum throw ability, that he can maintain the same contact time with the ball regardless of how high it comes down on him. Howver, your and my experiments are under different premises.
