This whole unit thing of mols is somewhat tricky and interesting. if
  • Thread starter Thread starter LT72884
    Interesting Unit
The discussion revolves around the concept of moles and their relationship to mass in chemistry. It clarifies that one mole of a substance is defined as Avogadro's number of particles, which is approximately 6.022 x 10^23. The confusion arises from equating grams with moles. For example, while one mole of sodium (Na) weighs 23 grams, one mole of sodium chloride (NaCl) has a molar mass of 58 grams. Therefore, 100.3 grams of NaCl corresponds to approximately 1.73 moles, calculated by dividing the mass by the molar mass. The key takeaway is that the mass of a mole is derived from the atomic mass of its constituents multiplied by Avogadro's number, distinguishing between the concepts of moles and mass.
LT72884
This whole unit thing of mols is somewhat tricky and interesting. if one mol of Na is 23g, then wouldn't 100.3g of NaCl be one Mol as well. I am under the impression from my lecture notes in class that the grams of a substance is the same a s a mol. I was asked a school of thought question by the profesor. How many mols is in 100.3g of NaCl. I said one because the notes stated that the grams of the substance is also equal to one mol. But as i write this i am puttign things together.
is it only one mol IF the grams of whatever happen to be equal to the amu. so NaCl has a molar mass of 58. if the question was asked, if you had 58g of NaCl, then that would be ONE mol right. it couldn't be the 100.3g is one mol because the 100.3g is not equal to the amu of NaCl
thanks guys.
Chemistry news on Phys.org
not quite so. one mol of any substance, is the atomic mass of its constituents, times the Avogardo's constant (a very large number). the atomic mass is in terms of the atomic mass unit, where each nucleon weights roughly 1 units. the avogardo's constant then can connect your nucleon mass to grams, because one mol of anything, weights exactly the same as the atomic mass number (or the number of nucleons) of that thing in grams. 100 grams of NaCl is therefore 100/58 or roughly 2 mols.
You mean the molar mass is what follows after the bold part, I suppose.
you don't say one molar mass of chlorine do you, you say one mol of chlorine, and what you mean is an avogardo's number of them, which weigh one avogadro's number times their atomic mass times the mass of nucleons in grams.
"One mol" and the "mass of a mol" are two different things.
Multiplying atomic mass of the constituents by Avogrado's number you obtain the mass of a mol of that substance and this is called molar mass.
The result is the mass of the mol and not the mol itself.
A mol is defined without any reference to the mass of the constituents. It's just Avogrado number of particles.
More general, the mass of an object is not the same thing as the object itself.
26K
12K
38K
