Thought experiment: charged particles
In summary: What did you mean by earlier?I meant earlier when I said that "In summary, In classical theory the time and (consequently) acceleration of the particles will be the same in both frames." This is not always the case in non-inertial frames.
davidge
554
Suppose we have two charged particles on the laboratory and two observers A and B.
##A## is inside one of the charges (never mind how)
##B## is sitting at the laboratory
In the lab reference frame we accelerate the particles. According to ##A## there will be only electric attraction or repulsion, depending on the sign of the charges. But according to ##B## there also will be a magnetic force due to the movement of the particles.
Now suppose we stop the particles from moving (according to lab frame) and we measure their relative distance. Both observers ##A## and ##B## have to find out the same distance, but since ##F = ma##, in the frame that there were two forces (electric and magnetic forces) there was a greater acceleration and consequently the charges would be more distant from each other.
How do we solve this problem?
Even if acceleration is the same and starts at the same time for both particles, A and B will not agree on what at the same time means.
A's frame is non inertial. None of the usual reasoning holds. I am not even sure that there is a way even in principle to separate electric and magnetic fields in such a frame.
You are correct, after starting this thread I considered the situation more carefully. See below
So are you saying that even that the particles don't move at all in ##A##'s frame, we still would have a magnetic field in that frame?
Consider the following:
In classical theory the time and (consequently) acceleration of the particles will be the same in both frames. So if ##F = ma## is still valid in this thought experiment, then the force of interaction between the particles is the same in both frames. But in ##B##'s frame there is a additional force, namely the magnetic force. The solution is that the electric field measured in ##B##'s frame differs from the one measured in ##A##'s frame. It's not surprising, because I guess since before Relativity coming up, physicists knew that a electrostatic field -the one that we can measure using Coulomb' theory- is different from the electric field of a moving charge.
Now, let ##t_o##, ##E_o##, ##m_o##, ##a_o## be the time, electric field, mass and acceleration of a particle in ##A##'s frame and quantities without a subscript be the quantities in ##B##'s frame. Additionaly, let the particle charge be ##q## -it's the same in both frames-.
We know that ##dt = \gamma dt_o## and so, ##a = a_o / \gamma##. If ##F = ma## is true, then ##E = E_o / \gamma##.
Therefore for ##B## we have ##q( \gamma E_o + v \times B) = m a_o / \gamma##. Divinding by the force in ##A##'s frame and arranging terms, we get
$$-v^2 \ \gamma \ \vec{E_o} = \vec{v} \times \vec{B}$$ where I've taken ##\vec{v}## to be the velocity of both particles relative to the lab.
Is this correct?
EDIT: Just realized that the electric field in ##B## would be ##E_o / \gamma##, and so the conclusion is that the magnetic field should be zero in the lab frame. So is relativity showing us that the magnetic field doesn't exist?
davidge said:
So are you saying that even that the particles don't move at all in A's frame, we still would have a magnetic field in that frame?
No, I am saying that in non-inertial frames there isn't always something that you can even identify as a magnetic field.
This is not true in non-inertial frames.
davidge said:
So if F=ma is still valid
It is not valid in non-inertial frames, that is what makes it non-inertial.
davidge said:
We know that dt=γ dt_o and so, a=ao/γ. If F=ma is true, then E=Eo/γ.
None of this is necessarily correct in non-inertial frames. You actually have to work out each one of these expressions to see if they are valid in the specific non-inertial frame under consideration. You simply cannot use arguments based on inertial frames when working with non-inertial frames.
Why the particle frame is non inertial? As its velocity is constant, I don't see why it's non inertial.
Please clarify
Because earlier you said "In the lab reference frame we accelerate the particles.", which is not consistent with the lab frame being inertial and the frame in which the particles are at rest also being inertial and the particle frame having a constant velocity. Only one of them can be inertial, and it will be the one in which objects at rest do not experience proper accelerations.
Oh, ok. What I mean is in the lab frame we accelerate the particles up to a velocity ##v##, possibly with their velocities going from zero to ##v## in a very short time.
So then the reference frame of the particles is non inertial. That is A's frame. The velocity is not constant.
If you're looking at the problem that way, you can limit your attention to the period of time between the two accelerations. Solve the problem once using an inertial frame in which the lab is at rest, and again using an inertial frame in which the particles are at rest after they have accelerated (which is to say that before the first and after the second acceleration they are moving along with the lab). The amount of time that the particles are in motion and subject to magnetic forces will be different in the two frames, the magnitude of the electrical field will be different in the two frames, the magnitude of the magnetic field will be different in the two frames... And all of these differences will come together in such a way that the invariants such as proper acceleration and proper time under acceleration are the same.
Likes Douglas Sunday
Nugatory said:
If you're looking at the problem that way, you can limit your attention to the period of time between the two accelerations. Solve the problem once using an inertial frame in which the lab is at rest, and again using an inertial frame in which the particles are at rest after they have accelerated (which is to say that before and after the acceleration they are moving along with the lab). The amount of time that the particles are in motion and subject to magnetic forces will be different in the two frames, the magnitude of the electrical field will be different in the two frames, and the magnitude of the magnetic field will be different in the two frames... And all of these differences will come together in such a way that the invariants such as proper acceleration and proper time under acceleration are the same.
This is what I did in post #4. Or that analysis of the problem isn't correct?
The velocity is constant after some time
Is it? There you assumed that the times and the coordinate accelerations would be the same in both frames.
No, please read it again.
Do you mean classical Newtonian theory of motion, or classical (non-quantum) Relativity?
non - relativistic theory, ie. Newtonian theory
Constant after some time isn't the same as constant. If you want to specify an inertial frame then you should say "moving uniformly" from the beginning.
Plus you add this in, to further make the scenario non inertial.
davidge said:
Both observers A and B have to find out the same distance,
Why? Inertial frames don't have to agree on distance. So are you going back to a non inertial frame whose distances are defined the same as the lab frame?
davidge said:
since F=ma, in the frame that there were two forces (electric and magnetic forces) there was a greater acceleration and consequently the charges would be more distant from each other.
So now you are going back to inertial frames where distances are in fact different.
Your scenario is hopelessly muddled now. I would recommend starting over in a new thread with a much more carefully arranged and described scenario.
Likes davidge
Perhaps it would be easier to describe and analyze if you used the principle of equivalence backwards:
Two charges are resting in an upper floor of a tall building.
Then the support is removed and the charges fall to the ground, where they stop.
It makes it clear that the charges don't feel a magnetic field at any time.
@davidge , you may want to write out a few intermediate steps of your derivation, I don't see how the "arranged" equation follows from what is said before.
Also if you start another thread, don't name the lab frame B, or use the phrase "frame B" instead of just "B".
Likes davidge
@davidge it is perfectly acceptable to not attach a reference frame to the charge. You can simply state that there is a lab frame and a moving frame, both inertial, with relative velocity v. Then you can fully describe the acceleration and deceleration in one inertial frame, and transform into the other inertial frame.
Likes davidge
Thanks Dale and SlowThinker.
I was looking the Feynman Lectures available on Caltech Website, where this topic is discussed. I will read it and start another thread if some doubt remain.
Related to Thought experiment: charged particles
1. What is a thought experiment?
A thought experiment is a mental exercise used to explore and analyze complex concepts or theories. It involves imagining a scenario or situation and reasoning through it to draw conclusions.
2. What are charged particles?
Charged particles are subatomic particles that have an electric charge, either positive or negative. Examples include protons, electrons, and ions.
3. How are charged particles used in thought experiments?
Charged particles are often used in thought experiments to explore concepts such as electromagnetism, electric fields, and the behavior of charged particles in different scenarios. They allow scientists to visualize and make predictions about the behavior of these particles without the need for physical experiments.
4. What are some famous thought experiments involving charged particles?
One famous thought experiment involving charged particles is the Millikan oil drop experiment, which helped determine the charge of an electron. Another is the double-slit experiment, which demonstrates the wave-particle duality of electrons and their behavior in electric fields.
5. What are the limitations of thought experiments involving charged particles?
Thought experiments involving charged particles are limited by the accuracy of the assumptions and simplifications made in the scenario. They also cannot account for all possible variables and may not accurately reflect real-world situations. Physical experiments are still necessary to confirm the results of thought experiments.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
