Thought experiment violates Heisenberg? (of course not)
In summary: But in our experiment, we don't have that knowledge, so we can't make a measurement of position and momentum.In summary, the position and momentum of the particle can be determined after the slit has been crossed, but before it interacted with the detector.
entropy1
1,230
71
Suppose we have an elementary double-slit experiment: A laser fires individual photons through a double slit at a detectionscreen made of atoms.
As we fire photons, an interference pattern emerges, exposing the momentum of the photons (the frequency of the laser).
So, we have registration of all the individual positions of the photons that impacted the screen, along with their momenta. Doesn't this violate the Heisenberg uncertainty relation? How can there emerge an interferencepattern anyway in that case?
One could argue that a large number of measurements approaches classical mechanics. But the atoms that make up the detectionscreen register the impact (momenta) of individual photons also. So this seems to violate the HUR too!
I am not seeing the solution to this clearly.
Have you learned the position and the momentum of the particle before it interacted with the slit, after it interacted with the slit, or do you know the value of one before that interaction and the value of the other after that interaction?
And are you paying attention to the exact time that each spot appeared on your detector? How precisely are you nailing down the exact position of the particle when it interacts with the detector?
Hello Nugatory. I take your questions not for retorical. In my example, there is nothing known about the future positions of the photons on the detectorscreen (a screen made of for instance: gold foil?) until they hit the detector. The momenta of the photons however can be deduced right at the beginning from the frequency of the laser. The exact time the photons hit the screen I don't take in consideration. (and I am curious why you ask the latter, for I have always wondered if the positions of interfering photons depend on time :smile: )
That gives you the momentum before the interaction with the slit. The interaction with the slit helps narrow down the position, but it also changes the momentum.
If you're not paying attention to when the spot appears at the detector you don't have much of a position measurement - all you have is "dunno where it is, but a while ago it was somewhere between the slit and the spot".
You might want to get hold of Ghirardi's "Sneaking a look at God's cards", which has a thorough but layman-friendly discussion of what's going on as the particle interacts with the slits.
(You also want to be a bit cautious about doing this thought experiment with photons instead of massive particles - it hasn't mattered yet, but the difficulties of assigning a position to a photon in flight will start to get in the way as you dig deeper into the problem).
Likes entropy1
The uncertainty in the momentum is almost at right angles to the initial momentum as is the uncertainty as to which slit it went through.
Well, you could just take a laser and fire it directly at the detector (no slits). While the photon is "in flight" you know its momentum quite precisely (from the label on the side of the laser) but its position is not even defined (no position operator for photon). When it hits the detector, you know its position quite precisely; but the photon no longer exists, so its momentum is no longer defined.
Ok, you say, but just before it hit (a picosecond, let's say) I know its momentum; plus I can "retrodict" its position, on the line between the laser and the detection point, a light-picosecond in front of the detector. No: there's no position operator. You're not allowed to suppose this apparently logical conclusion.
Ok, let's do it with an electron instead. Now I'm allowed to retrodict the position, because an electron in flight does have a position. But I have to know the exact time it hit. The extra experimental apparatus to determine that, however it works, will inevitably introduce extra uncertainty into the momentum and/or position. Plus, the electron source can't be as accurate as a laser; there will be a considerably greater uncertainty in the electron's momentum (and speed) than with the photon.
Without doing detailed calculations we can be quite certain Heisenberg will not be violated by our experiment.
Of course I could be misunderstanding something.
Part of the resolution is that the momentum you measure from the interference pattern is the momentum of the particle just after the slit.
The position you measure is the position at the screen. You have not measured the position of the particle just after the slit. In other words, you have not measured canonically conjugate position and momentum, which are the position and momentum in the uncertainty principle.
In very special cases (when one has some knowledge of the state), one can make a simultaneous "measurement" of position and momentum. However, what is forbidden is to do so for an arbitrary unknown state.
Related to Thought experiment violates Heisenberg? (of course not)
1. What is a thought experiment that violates Heisenberg's Uncertainty Principle?
A common thought experiment that violates Heisenberg's Uncertainty Principle is the "Schrödinger's cat" experiment. In this experiment, a cat is placed in a sealed box with a vial of poison that will be released based on the random decay of a radioactive substance. According to Heisenberg's principle, it is impossible to know both the exact position and velocity of the radioactive substance, and therefore, it is also impossible to predict the outcome of the experiment with certainty.
2. How does the thought experiment of Schrödinger's cat violate Heisenberg's Uncertainty Principle?
In the Schrödinger's cat experiment, the uncertainty principle is violated because the position and velocity of the radioactive substance are both known precisely in the thought experiment, even though this is impossible in reality. This leads to a paradox where the cat is simultaneously dead and alive, violating the principle that an object cannot exist in two states at once.
3. Can thought experiments be used to disprove Heisenberg's Uncertainty Principle?
No, thought experiments cannot be used to disprove Heisenberg's Uncertainty Principle. This principle is a fundamental law of quantum mechanics and has been extensively tested and confirmed through various experiments and observations. Thought experiments may challenge our understanding of the principle, but they cannot disprove it.
4. Are there any real-life examples that demonstrate the validity of Heisenberg's Uncertainty Principle?
Yes, there are many real-life examples that demonstrate the validity of Heisenberg's Uncertainty Principle. One example is the use of electron microscopes, which rely on the principle to produce images of tiny objects. Another example is the phenomenon of quantum tunneling, where particles can pass through barriers that they would not be able to overcome according to classical physics.
5. How does Heisenberg's Uncertainty Principle impact our understanding of the physical world?
Heisenberg's Uncertainty Principle has a significant impact on our understanding of the physical world, particularly at the quantum level. It implies that it is impossible to have complete knowledge and control over the behavior of subatomic particles, and that there will always be a degree of uncertainty in our measurements. This principle has also led to the development of new theories and technologies, such as quantum mechanics and quantum computing.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
