lksmith17
- 12
A block with a mass of 25 kg is hung midway between two pulleys, with a rope connecting a hook at the top of the block to each of the two pulleys. On the other side of the pulleys, both ropes are connected to blocks with masses of 15 kg. The 25 kg mass in the middle sags downward until the 3 blocks and 2 pulleys form the shape of an “M”. If the pulleys are 45 cm apart, how far below the level of the pulleys does the top of the 25 kg mass need to be in order for the system to be in equilibrium?
Sum of Forces =0
I have calculated the tensions in one rope to be 147N using 15kg*9.8m/sec^2 and the Fg of the middle block is 245N I know I need to find the angles of the rope to the ceiling by splitting the tension of the rope in x and y directions, but I can not figure out how to get those values.
