r34racer01
- 63
Three identical, solid, uniform density cylinders, each of mass 16 kg and radius 1 m, are mounted on frictionless axles that are attached to brackets of negligible mass. A string connects the brackets of cylinders #1 and #3 and passes without slipping over cylinder #2, whose bracket is attached to the ledge. Cylinder #1 rolls without slipping across the rough ledge as cylinder #3 falls downward.
This system is released from rest from the position shown -- with cylinder #3 at a height of 4.4 m above the ground.
a) How fast is cylinder #3 moving just before it hits the ground?
v = 5.36
b) What is the rotational speed of cylinder #2 at the time in (a)?
w = 5.36
c) Cylinder #3 is now replaced by a sphere of the same mass. How fast is it moving just before it hits the ground?
v'= 5.36
d) Finally, cylinder #1 is replaced by a sphere of the same mass and radius. How fast is cylinder #3 moving just before it hits the ground?
v'' = ?
This is where I'm having problems. This should be exactly the same as pt. A except we have a sphere so c=2/5. So I did
mgh = 2/5mv^2
(16)(9.81)(4.4) = 2/5(16)v^2
and I got 10.388 = v'' but apparently that's wrong, anyone know what's going on?
