Three Difficult Materials Questions (check my answers)
  • Thread starter DizzyDoo
  • Tags
    Materials
In summary, the conversation discusses three difficult materials questions and the person has provided their best attempt at answering them but wants others to check their answers for accuracy. The questions involve calculating the extension or compression of various materials under different weights and using the Young Modulus equation. The answers to the first two questions appear to be correct, but the answer to the third question may be missing something. The conversation also includes a helpful tip on understanding tension and compression forces.
DizzyDoo
[SOLVED] Three Difficult Materials Questions (check my answers!)
Hi there. As you can see below, there are three questions on materials, that are quite difficult in my opinion. I've given my best attempt at them, checked them, and I think they are correct. However, as I am prone to making stupid mistakes, and I really want to get all three 100% right, I'd really appreciate it if one or two people could see if they get the same answers as me. Thanks!
Question 1: A steel wire of diameter 0.5mm and length 1.84 is suspended vertically from a fixed point and used to support a 60N weight hung from the lower end of the wire. The Young Modulus for steel is 2.0x10^11 Nm^-2. Calculate the extension of the wire.
Question 2: A 3500kg statue is placed on top of a cylindrical concrete (Young Modulus = 2.3x10^10 Nm^-2) stand. The stand has a cross-sectional area of 7.3x10^-2 m^2 and a height of 1.8m. By how much does the statue compress the stand?
Question 3: A 72kg mountain climber hangs on a nylon rope (radius = 6.5mm). If the rope stretches by 5.0x10^-2m what is the un-stretched length of the rope? (Young Modulus of nylon = 1x10^9 NM^-2
YM = Stress / Strain
Stress = Force / Area
Strain = eXtension / Length
Area of circle = (pie)r^2
Firstly I changed the diameter of 0.5mm into metres:
0.5 / 1000 = 0.0005m
I then worked out the area of the wire:
(pie)x(0.0005/2)^2 = 1.9x10^-7
I then stuck every value into the Young Modulus equation:
2.0x10^11 = (60 / 1.9x10^-7) / (x / 1.84)
2.0x10^11 = 305577490.7 / (x / 1.84)
Stuck with the extension on the wrong side, so a quick bit of rearranging and...
x = (305577490.7 / 2.0 x 10^11) x 1.8
x = 0.001527887 x 1.8
x = 0.00275m
x = 2.7x10^-3m
2) First off, I get the force from the mass (weight):
3500 x 9.81 = 34335
Stick my information into the young modulus equation:
2.3x10^10 = (34335 / 7.3x10^-2) / (x / 1.8)
Solve and rearrange:
x = (470342 / 2.3x10^10) x 1.8
x = 0.000036
x = 3.6 x 10^-5 However, the question asks for the compression, so is the answer correct?
3) Again, firstly I work out the force with the mass...
72 x 9.81 = 706.32
And change the radius into metres, so I can use it:
6.5mm / 1000 = 0.0065m
Work out the area of the rope:
(pie)x 0.0065^2
Now, stick all that I have into the young modulus equation:
1x10^9 = (706.32 / 0.000132732) / (5.10^-2 / L)
1x10^9 = 5321387.9 / (5x10^-2 / L)
Time to rearrange and solve: (Check my rearranging!)
L = (5x10^-2 x 1x10^9) / 5321387.9
L = 7.2m (Which sounds about right in my common sense check)
I understand that's a lot to check, but hopefully I've made it clear enough for anyone wanting to lend a hand. Thank you muchly for your time!
Axial extensions or compression D = (P*L)/(A*YM) --> P = applied force
P/A is the applied stress, L is the length and A is the Area
The answers to 1 and 2 look correct to me.
The answer to 3 something seems to be missing something. D*A*YM / P = L
I get 9.39m but you should check my math.
When an applied force extends an object it is called a "tension" or "tensile" force.
When an applied force compresses or shortens an object it is called "compression" or "compressive" force.
Hi! I can confirm that your solutions for all three questions are correct. Your calculations and use of equations are accurate and your steps are well-explained. Great job on solving these difficult materials questions! Keep up the good work!
Related to Three Difficult Materials Questions (check my answers)
1. What are the three difficult materials questions?
The three difficult materials questions are: What is the difference between a solid and a liquid? What is the atomic structure of a diamond? How is glass made?
2. Can you explain the difference between a solid and a liquid?
A solid is a state of matter in which the particles are tightly packed together and have a fixed shape and volume. A liquid is a state of matter in which the particles are close together but can move around and take the shape of their container.
3. What is the atomic structure of a diamond?
Diamond is made up of carbon atoms arranged in a specific crystal lattice structure. Each carbon atom is bonded to four other carbon atoms in a tetrahedral shape, resulting in a very strong and rigid structure.
4. How is glass made?
Glass is made by heating a mixture of sand, soda ash, and limestone until it becomes molten. The molten glass is then shaped and cooled to form a solid material.
5. Why is diamond considered the hardest material?
Diamond is considered the hardest material because of its unique crystal lattice structure. The strong bonds between carbon atoms make it difficult to break or scratch the surface of a diamond.
10K
11K
