Three dimensional ##\delta## function
  • Thread starter Apashanka
  • Tags
    Function
In summary, the Dirac delta in spherical coordinates is a function that can be expressed as ## \delta(\vec r)= \frac 1 {r^2\sin \theta} \delta(r-r')\delta(\theta-\theta')\delta(\phi-\phi') ##. To reduce the right-hand side of the given equation to volume integral form, we simply need to multiply it by ## \frac {r^2\sin\theta}{r^2\sin\theta} ##. This can be useful in solving problems involving spherical coordinates.
Apashanka
429
Three dimensional Delta function
##r,\theta,\phi## are the usual spherical polar coordinate system.
##\int_v\nabla•(\frac{\hat r}{r})dv## over a spherical volume of radius ##R## reduces to ##\int_s(\frac{\hat r}{r})•\vec ds=4\pi R##
Now ##r## runs from 0 to ##R,\theta## from 0 to ##\pi## and ##\phi## from 0 to ##2\pi##.
In terms of ##\delta## function ##\int_{0}^{R} \delta (r-r')dr=1## where ##r'## lies within 0 to R ,and ##\ne 0,R##,similarly for ##\theta## and ##\phi## also where ##\int_{0}^{\pi} \delta(\theta-\theta')d\theta=1## where ##\theta'## lies ##{0,\pi}## and ##\ne0,\pi## similarly for ##\phi## also.
Putting them
##\int_v(\nabla•\frac{\hat r}{r})dv=4\pi R\int_0^R\int_0^\pi \int_0^{2\pi} \delta(r-r')\delta(\theta-\theta')\delta(\phi-\phi')drd\theta d\phi##
can anyone please tell me how can the RHS be reduced to volume integral form??
Actually, the Dirac delta in spherical coordinates is: ## \delta(\vec r)= \frac 1 {r^2} \delta(r-r')\delta(\cos\theta-\cos\theta')\delta(\phi-\phi')=\frac 1 {r^2\sin \theta} \delta(r-r')\delta(\theta-\theta')\delta(\phi-\phi') ##
So you just need to multiply the RHS by ## \frac {r^2\sin\theta}{r^2\sin\theta} ##.
P.S.
You may find this useful.
P.S.
Thanks
Related to Three dimensional ##\delta## function
What is a three dimensional ##\delta## function?
A three dimensional ##\delta## function, also known as a three dimensional Dirac delta function, is a mathematical function that represents a point in three-dimensional space. It is defined as zero everywhere except at the origin, where it is infinite, and has a total integral of one.
What is the purpose of a three dimensional ##\delta## function?
A three dimensional ##\delta## function is often used in physics and engineering to represent point sources or point masses in three-dimensional space. It can also be used to simplify calculations involving three-dimensional integrals.
How is a three dimensional ##\delta## function different from a one dimensional ##\delta## function?
A three dimensional ##\delta## function is similar to a one dimensional ##\delta## function in that it is zero everywhere except at a single point. However, a three dimensional ##\delta## function has a value of infinity at the origin, while a one dimensional ##\delta## function has a value of infinity at the point where it is defined.
Can a three dimensional ##\delta## function be graphed?
No, a three dimensional ##\delta## function cannot be graphed in the traditional sense because it is infinite at a single point. However, it can be represented graphically using a three-dimensional plot, with the value of infinity at the origin and zero everywhere else.
What are some real-world applications of a three dimensional ##\delta## function?
A three dimensional ##\delta## function has many applications in physics and engineering, including representing point sources in electromagnetic fields, modeling point masses in gravitational fields, and simplifying calculations involving three-dimensional integrals. It is also used in image processing and computer graphics to represent sharp edges and corners in three-dimensional objects.
