Three dimensional representation of ##U(1)\times SU(2)##
In summary: The mass term for a triplet is given by [1]:$$ \mathcal{L} \supset -\frac m 3 \left( 3 L^+ L^- +L^{0} L^{0} \right) $$
Ramtin123
Consider a three dimensional representation of ##U(1)\times SU(2)## with zero hypercharge ##Y=0##:
$$ L= \begin{pmatrix} L^+ \\ L^0 \\ L^- \end{pmatrix} $$
Then the mass term is given by [1]:
$$ \mathcal{L} \supset -\frac m 2 \left( 2 L^+ L^- +L^0 L^0 \right) $$
I am wondering where the mass term is coming from.
I know that in the Standard Model the mass term for a doublet which is in two dimensional representation, is given by ## m \bar L L##.
Any ideas or comments appreciated.
Reference:
  1. Eqn (4) in arXiv:0710.1668v2 [hep-ph]
It is just a parameter of the Lagrangian. Since ##L## is a full non-chiral Dirac fermion, there is no problem in introducing that mass term, just as there is no problem in introducing a mass term in QED. The problem in introducing fermion masses in the SM is that the SM is chiral and left- and right-handed fields transform differently under SU(2). In turn, this means that the mass term needs to be generated through something like the Higgs mechanism, but this is not an issue here.
Thanks Orodruin . So, in this case mass term should read:
$$ -\frac m 2 \bar L L = -\frac m 2 \left( L^{+†} L^+ + L^{0†} L^0 + L^{-†} L^- \right)$$
So, why should this expression be the same as the expression above in eqn (4) of arXiv:0710.1668v2 [hep-ph] ?
Isn't this the same up to a constant?
##L^+##, ##L^0## and ##L^-## are independent fields. Let's call them ##\psi^+##, ##\phi^0## and ##\chi^-##.
So I am wondering why ##\psi^{+†}=\chi^-## or ##\chi^{-†}=\psi^+## ?
Then I didn't understand your notation. Which particular model are you discussing?
I am adding a triplet to electro-weak sector of the Standard Model. The triplet is in real non-chiral representation of ##SU(2)_L \times U(1)_Y##, and has vanishing hyper charge ##Y=0##.
The model is discussed in details in section 3.1 of this paper.
FAQ: Three dimensional representation of ##U(1)\times SU(2)##
What does "U(1) x SU(2)" mean?
"U(1) x SU(2)" refers to the mathematical notation for the product of two groups, U(1) and SU(2). This notation is commonly used in theoretical physics to describe symmetries in particle physics and quantum field theory.
What is the significance of a three-dimensional representation of U(1) x SU(2)?
A three-dimensional representation of U(1) x SU(2) is important in understanding the behavior of particles and fields in three-dimensional space. It allows for a more comprehensive understanding of the symmetries and interactions in particle physics and can be used to make predictions about experimental results.
How is a three-dimensional representation of U(1) x SU(2) constructed?
A three-dimensional representation of U(1) x SU(2) is constructed by assigning mathematical objects called representation matrices to each element of the group. These matrices have specific properties and can be used to transform vectors in three-dimensional space according to the symmetries of the group.
What are some applications of a three-dimensional representation of U(1) x SU(2)?
A three-dimensional representation of U(1) x SU(2) has many applications in theoretical physics. It is used to study the behavior of particles and fields in quantum field theory, as well as in the development of theories such as the Standard Model. It also has applications in condensed matter physics, where symmetries play a crucial role in understanding the properties of materials.
Are there any limitations to using a three-dimensional representation of U(1) x SU(2)?
While a three-dimensional representation of U(1) x SU(2) is a powerful tool in theoretical physics, it is not a complete representation of all possible symmetries. In some cases, higher-dimensional representations may be needed to fully describe the behavior of particles and fields. Additionally, the mathematical calculations involved in using these representations can be complex and difficult to solve, making it challenging to apply in certain situations.
