Three hanging balls of uniformly distributed charge
In summary, the problem involves three identical small balls with a mass m and a uniformly distributed charge Q, hanging from a string of length L. The strings are all tethered at one end at the same point. To find the general equation for the angle θ of each string from vertical, a free body diagram is drawn and the forces in the x and y directions are collected. Using these forces, the equations for Tension in both directions are obtained. However, when trying to solve for θ, a problem arises due to the incorrect value for the distance between the balls in the force due to a charge. The correct value is found using the Law of Sines, resulting in a third-order equation for tanθ. The Coulomb
derravaragh
24
Three identical small balls of mass m with uniformly distributed charge Q each hang from a string of length L. The strings are all tethered at the opposite end at the same point.
(a) Find the general equation for the angle θ of each string from vertical.
I started off by drawing a free body diagram, obtaining a Tension in both the x and y directions, a downward force (m*g) and a horizontal force away in the x-direction (the force due to the other charges). I then collected the Forces for the x and y directions:
Fy = Tcos(θ) - mg = 0
Fx = Tsin(θ) - Q2/(3*L2*sin2(θ))
Using Fy I solve for T to be mg/cos(θ) and plug it in for T in Fx. However, a problem arises when I try to solve for θ, I end up with:
tan(θ)sin2(θ) = Q2/(3L2mg)
I do not know how to solve this for θ, and when re-evaluating my work, I feel my value for the distance between balls in the force due to a charge is incorrect. The balls make a triangle, and with the invisible line down the center, you can divide that triangle into three even 30-30-120 triangles. I determined the distance between one ball and the center to be Lsin(θ), and using the Law of Sines, determined r (the distance between two balls) to be:
r = √(3)*L*sin(θ)
If this is correct, I'm not sure where I went wrong. Any hints would be appreciated. Thanks.
r = √(3)*L*sin(θ)
Your equations for r is correct. The force on a charge is the vector sum of the Coulomb forces from the other two charges. Take that into account. And do not forget the factor k from the Coulomb force!
At the end, you get a third -order equation for tanθ, replacing sin2θ by tan2θ/(1+tan2θ)
ehild
FAQ: Three hanging balls of uniformly distributed charge
What is the concept of "Three hanging balls of uniformly distributed charge"?
Three hanging balls of uniformly distributed charge is a theoretical scenario in physics where three identical spheres are suspended in air and are each uniformly charged with the same amount of charge. This scenario is often used in electrostatics to demonstrate the principles of electric force and potential energy.
How is the electric force calculated in this scenario?
The electric force between the three hanging balls of uniformly distributed charge can be calculated using Coulomb's law, which states that the magnitude of the force between two charges is directly proportional to the product of the charges and inversely proportional to the square of the distance between them.
What is the significance of uniform charge distribution in this scenario?
The uniform charge distribution ensures that the electric force between the balls is evenly distributed, creating a balanced and stable system. This allows for a more accurate and simplified calculation of the electric force and potential energy in the scenario.
Can the three hanging balls of uniformly distributed charge scenario be applied to real-life situations?
While this scenario may seem theoretical, it can be applied to real-life situations such as the behavior of charged particles in a plasma or the interaction between multiple charged molecules in a solution. It is also used in the design of electrostatic devices, such as particle accelerators.
How does the distance between the hanging balls affect the electric force and potential energy?
The distance between the hanging balls directly affects the magnitude of the electric force and potential energy. As the distance between the balls decreases, the force and potential energy increase, and vice versa. This is due to the inverse square relationship in Coulomb's law.
