Three-phase voltage inverter (some questions)
Three-phase voltage inverters are complex devices that require a solid understanding of electrical engineering principles. To gain knowledge, it's recommended to start with visual resources like Google Images to explore circuit diagrams and configurations. Additionally, seeking out educational websites, online courses, and textbooks focused on power electronics can provide valuable insights. Engaging in forums or discussion groups dedicated to electrical engineering may also yield helpful information and answers. Understanding these concepts is crucial for effectively tackling related questions and assignments.
polibuda
Three-phase voltage inverter. How many instantaneous values can: phase-to-phase voltage, phase voltage, control signal, phase current in the case of a symmetrical load RL connected in a star without a neutral conductor? How many combinations of transistors of such a converter are there? Which give the same output voltage?
lack
I have no idea how to answer to these questions. Our teacher has given it to solve, but i don't know where I sholud to search informations. Could somebody recommend me valuable sources of knowledge?
I would probably start with a Google Images search on the circuits for 3-phase power inverters, and see where that leads me... :wink:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
