Three protons and two positrons....
In summary, the problem involves three protons and two positrons arranged in a square with a proton at the center, released from rest. The goal is to find the kinetic energy of the three protons after a long time. By assuming that the final potential energy is zero and using the equation for Coulomb's force, the solution shows that only the positrons will fly away and the protons will remain. This is due to the large difference in mass between the protons and positrons, resulting in a much greater acceleration for the positrons.
Titan97
There protons are and two positrons are held such that two protons are on the ends of a diagonal of a square and the two positrons are on the ends of the second diagonal. The third proton is situated at the centre of the square. The system is released from rest. Find the kinetic energy of the three protons after a long. (Side of square is ##a##)
$$F=\frac{ke^2}{a^2}$$
I tried solving the problem by assuming that final potential energy is ##0## since all particles except the proton at the centre of square will move to infinity due to rulsions and initial potential energy is $$\frac{4ke^2}{a}+\frac{2ke^2}{a\sqrt{2}}+\frac{4ke^2}{\frac{a}{\sqrt{2}}}$$
But in solution given, they have state that only the positrons will fly away and the protons will remain. How is this possible?
Does the solution actually say that none of the protons gain any KE, even after a long time?
Likes Titan97
No. Here is the picture:
OK. Compare the mass of a proton to the mass of a positron.
Likes Titan97
The mass of the positron will not affect the force with which it will repel the proton.
Why not?
Likes Titan97
Because F=kq/r^2.
Titan97 said:
Because F=kq/r^2.
OK.
At the instant of release, how does the magnitude of the net force on a positron compare to the magnitude of the net force on a proton?
At the instant of release, how does the magnitude of the acceleration of a positron compare to the magnitude of the acceleration of a proton?
Likes Titan97
I get it now. Acceleration of positron is far greater than that of the proton.
Yes. To a good approximation, you can neglect the motion of the corner protons during the time that the positrons move far enough away to have little influence on the protons.
Likes Titan97
Related to Three protons and two positrons....
1. What are protons and positrons?
Protons are positively charged particles that make up the nucleus of an atom. Positrons are the antiparticles of electrons, with the same mass but opposite charge.
2. How do three protons and two positrons behave?
Three protons and two positrons would form a helium nucleus, also known as an alpha particle. They would be attracted to each other by the strong nuclear force, and their charges would balance out to make a stable particle.
3. Can three protons and two positrons combine to form different elements?
No, three protons and two positrons will always form a helium nucleus. The number of protons determines the element, and since there are three protons, it will always be helium.
4. How are protons and positrons related to each other?
Protons and positrons are both subatomic particles that are found in the nuclei of atoms. They have the same mass, but opposite charges, making them antiparticles of each other.
5. What are the practical applications of three protons and two positrons?
Three protons and two positrons are used in nuclear reactions and fusion processes, such as in nuclear power plants. They can also be used in PET scans for medical imaging.
