Throw a ball, initial velocity?
In summary, a referee throws a ball in a basketball game from a height of 1.6 meters above the ground. The ball is caught 0.8 seconds later by a jumping player, when it is 2.7 meters above the ground and on the way down. The question asks for the initial velocity when the ball left the referee's hand. Using the equation s=v0t + at^2/2, the initial velocity is solved for by setting v=v0 + at and solving for v0. However, this gives the wrong answer, so the second equation is used instead. This is because the acceleration due to gravity is always constant and acts in the same direction, regardless of the direction of motion.
Drizzy
210
A referee throws a ball in a basketball game. When the ball was in his hand the heigh was 1,6 meters above the ground. The ball is caught 0.8 seconds later by a jumping player. The ball is 2.7 meters above the ground and on the way down. what was the initial velocity when the ball left the referee's hand?
s=v0t + at^2/2
v=v0 + at
I am guessing that the basketball player caught the ball when it was at its highest point and therefor the velocity was 0 m/s.
0 = v0 + at
at = - V0
-9,86 * 0,8 = - v=
9,82 * 0,8 = v
this answer is wrong so i tried again with the second equation and that gave the right anwer. Why is that?
Well the question says he caught it "on the way down", not at its highest point.
Since you know the distance and the time, but not the initial nor final velocity, I think you used the wrong equation to start with.
Hello.
Note that the ball is "on the way down" when it is caught. Is that compatible with your assumption that v = 0 at the time the ball is caught?
Edit: [I see Merlin already pointed this out.]
I think the problem should have stated that the ball was thrown vertically.
Ooops! My final comment is wrong. You may use that equation first or second, so long as you don't assume you know v.
In fact I think you may need to get two equations involving v and v0 so that you can eliminate v.
You know time and distance at both start and end, also you know the acceleration, but you have two unknown velocities.
but now that I think about it why can I use the second equation? because when the ball is going up its acceleration is -9.82 but when it is on its way down the acceleration is 9,82.
In answer to your query in #5, the second equation , v=v0 + at has two unknowns and you get v= v0 -9.8 x 0.8 which does not get you an answer yet.
I'm not sure what your second comment is about. gravity is a constant in this problem, so always has exactly the same value.
If we are taking UP as positive, then a = - 9.8 for all parts of the trajectory, because it is an acceleration downwards.
Now back to the story. First let me apologise for maybe leading you astray. It was late last night and I obviously was not thinking too clearly.
If you just use your second equation s = v0 x t + a x t2/2 you know everything except v0 so you can solve for that.
Write down all the values you know in the problem (so that I can check that you have these right) then attempt to solve that second equation.
You have to choose which direction is positive, up or down, and stick to it for all distances, velocities and accelerations.
If up is positive then, as Merlin posted, the acceleration is negative throughout. The velocity starts as positive and finishes as negative, so on the way up the negative acceleration attenuates the positive velocity, but on the way down it augments the negative velocity.
As TSny posted, there is not enough information. I'm not familiar with the formalities of basketball. If there is some context in which the referee would throw the ball straight up then that is probably what is missing. Otherwise, assume it meant to ask for the initial vertical velocity. Or perhaps you omitted some part of the question statement?
It doesn't make any sense for the referee to throw the ball with a horizontal component since that would give one team an advantage.
This is a common misconception. Note that at the highest point in the trajectory the acceleration is not zero!
You do not need to break the analysis of the motion into two separate parts. Equations like ##\Delta x=v_ot+\frac{1}{2}at^2## will give you the displacement regardless of whether or not the object changed direction during the displacement. So, for example, if it starts at a height of 0.9 m, travels upward to a height of 1.5 m, and then falls and is at a final height of 0.8 m, ##\Delta x## will be -0.1 m. On the other hand, if it starts at a height of 0.9 m and moves downward the entire time ending at a height of 0.8 m ##\Delta x## will also be -0.1 m, and that one equation is valid in both circumstances.
@haruspex In basketball there's a tip off, or jump ball, that occurs at the beginning of each period, or any time when two opposing players have a dispute over possession. The referee throws the ball directly upward and the two players jump, attempting to tip (or tap) the ball towards one of their team mates.
That's not correct. Gravity always acts in the same direction = downwards.
What if the ball starts at 1,6 meters and falls at 2,7 meters? is the displacement 1,1 because it is higher than the start or is it -1.1 cus it is FIRST Height - Last height?= displacement
I don't understand that statement. If the initial height is 1.6 m and the final height is 2.7 m, then the displacement is +1.1 m. We wouldn't call that a "fall"!
Always final position minus initial position. This is the reason velocity is negative when the position is decreasing, and positive when the position is increasing.
##\bar{v} = \frac{\Delta x}{\Delta t}##
Related to Throw a ball, initial velocity?
1. What is initial velocity?
Initial velocity is the speed and direction at which an object is launched or thrown. It is usually denoted by the symbol "v0" or "u".
2. How is initial velocity calculated?
Initial velocity can be calculated using the formula: v0 = (s - ut)/t, where v0 is the initial velocity, s is the distance traveled, u is the final velocity, and t is the time taken.
3. Does initial velocity affect the trajectory of a thrown ball?
Yes, initial velocity is one of the factors that affect the trajectory of a thrown ball. The higher the initial velocity, the farther and higher the ball will travel.
4. What is the relationship between initial velocity and final velocity?
The relationship between initial velocity and final velocity is given by the equation: v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time taken.
5. How does air resistance affect the initial velocity of a thrown ball?
Air resistance can decrease the initial velocity of a thrown ball by exerting a force in the opposite direction of motion. This can cause the ball to travel a shorter distance and have a lower final velocity.
