Thrush required to hover, take off and accelerate?
  • Thread starter Robert Rice
  • Tags
    Accelerate
In summary, to hover, the thrust or lift force must equal the total weight. To accelerate upward, the lift force must be greater than the weight. The acceleration can be calculated using the equation a = g * (L/W - 1), where g is the acceleration due to gravity and L and W are the lift and weight forces. In the example given, with a lift force of 300 lbs and a weight of 270 lbs, the acceleration would be 3.6 ft/s2.
Robert Rice
thrush required to hover, take off and accelerate?
i need equations to figure out the following
how much force is required to accelerate a mass. ie knowing either the mass or pounds of force,
how to figure out acceleration curve,
basically I am trying to figure out how much force(thrust) is required to move and accelerate an object 300 lb. an also how much force(thrust) would be requires to maintain a steady hover.
Sounds like Newton's second Law should help you out...
Robert, thanks for moving the question out of the blogs section.
It might help people answering to know some more information ... like is this a school homework question, a matter of personal curiosity, or relevant to a project you're working on?
Regards,
Mark
jet pack! using micro-jets..
jet pack.. ok let's say total weight of person, pack and fuel is 270 lbs and i have 300pounds of force available (1) at what rate would it accelerate from ground zero in vertical lift? (2) how much lift from a wing in required to achieve horizontal flight? (3) once horizontal flight is achieved, what would the acceleration curve be with the full 300 Lb/F applied.
Okay, looks like this is not homework, which gives people more freedom in providing answers.
In order to hover, the thrust or lift force must equal the total weight.
To accelerate upward, the lift force must be greater than the weight. The more the lift force, the greater the acceleration (as long as lift is greater than the weight).
If L is lift force and W is the weight, then the acceleration "a" is:
[tex]
a = g \frac{L-W}{W} \ \mbox{ or } \ g \cdot (\frac{L}{W}-1)
[/tex]
where g is the acceleration due to gravity of a free falling object: either 9.8 m/s2 or 32 ft/s2
Using your example:
L = 300 lbs
W = 270 lbs
[tex]
\begin{multline*}
a = 32 \ \frac{ft}{s^2} \ \frac{300-270}{270}\\
= 32 \ \frac{ft}{s^2} \ \frac{30}{270}\\
= 32 \ \frac{ft}{s^2} \ \frac{1}{9} \\ = \frac{32}{9} \ \frac{ft}{s^2}\\
= 3.6 \ \frac{ft}{s^2}
\end{multline*}
[/tex]
FAQ: Thrush required to hover, take off and accelerate?
1. How does a thrush hover?
A thrush hovers by using its strong wing muscles to flap its wings rapidly, creating enough lift to stay suspended in the air.
2. What is the required wing shape for a thrush to hover?
A thrush requires a flat, broad wing shape with high aspect ratio (length to width ratio) in order to generate enough lift to hover.
3. How does a thrush take off?
A thrush takes off by flapping its wings and using its powerful leg muscles to push off the ground and gain altitude.
4. How does a thrush accelerate?
A thrush accelerates by increasing the frequency of its wing flaps, tilting its body forward, and using its tail to steer and maintain balance.
5. What environmental factors affect a thrush's ability to hover, take off, and accelerate?
The main environmental factors that affect a thrush's ability to hover, take off, and accelerate include air density, wind speed and direction, temperature, and humidity. These factors can impact the amount of lift and thrust generated by the bird's wings, as well as its overall maneuverability and control in flight.
