PsychonautQQ
- 784
- 10
Thx for help tonight yall :D 3 more questions X_x
(1 pt)
First of all I'm a bit confused.. it wants the equation for a plane in all three questions.. the linear equation of a plane?
(A) If the positive z-axis points upward, an equation for a horizontal plane through the point (-5,4,-4) is
So it's a horizontal plane which means that the z direction number will be zero..
a(x-xi) + b(y-yi) + c(z-zi) = 0
ax - a5 + by - b4 = -
so i'll make a equal 4 and b = -5?
4x - 20 -5y +20 = 0
4x - 5y = 0
program says this is wrong..
(B) An equation for the plane perpendicular to the x-axis and passing through the point (-5,4,-4 is:
attempt at solution:
a plane that hits the x-axis at a 90 degree angel would mean that it always has the same value for x if I'm picturing this correctly? so the direction number for x would be zero i believe.
b(y-(-5)) + c(z-(-4)) = 0
by + 5b + cz + 4z = 0
so i could make b = 4 and z = -5?
4y + 20 - 5z - 20 = 0
4y - 5z = 0...
program says I'm doing it wrong X_x
(C) An equation for the plane parallel to the xz-plane and passing through the point (-5,4,-4) is:
If it's parallel to the xz plane that means the direction on it's y component must be zero..
a(x-(-5)) + b(y-4) + c(z-(-4)) = 0
ax + 5a + by - 4b + cz + 4c = 0
well b has to be zero so it's parallel to the xz plane...
so xa + 5a -cz + 4c = 0
c could be -5 and a could be 4... ?
4x + 20 +5z -20 = 0
4x + 5z = 0
something went wrong here...?
(1 pt)
4x - 20 -5y +20 = 0
4x - 5y = 0
4y - 5z = 0...
4x + 20 +5z -20 = 0
4x + 5z = 0
