THz radiation detection with a conductor
In summary, it is possible to detect THz radiation (300 GHz - 1 THz) with conductor or dipole antennas used to detect radio waves. However, there are limitations and challenges such as atmospheric absorption and the need for advanced semiconductor technology. The size of the antenna is not the main limiting factor, but phased array dipoles or parabolic reflectors may be necessary to compensate for the small aperture of millimeter wavelength dipoles.
Mikhail_MR
Hello!
Is it possible to detect THz radiation (300 GHz - 1 THz) with conductor or dipole antenna used to detect radio waves?
I know that THz radiation may be detected in spectroscopic set-ups with a photoconductive antenna based on the semiconductor. In this case, the light from laser create free electrons and holes and the oscillation of the electric field of the THz radiation leads to the current on the antenna. Can I use only the oscillation of E-field to make current on the antenna if I use the conductor?
Is it correct that the limitation that the size of the antenna must be in order with wavelength is the reason?
With best regards!
Mikhail_MR
Yes, it is possible to use small metallic dipoles, but there are many problems. Far-IR is radiated by black-body objects at room temperatures, including the atmosphere. The atmosphere absorbs Far-IR.
https://en.wikipedia.org/wiki/Atacama_Large_Millimeter_Array
Semiconductor technology has now passed 300GHz = 1mm. Heterodyne down-conversion receivers made from SiGe single chip integrated mixers and oscillators are becoming available. They have application in molecular spectroscopy and fingerprinting chemical materials, also for security and medical imaging. The mass production of Far-IR data links may stimulate the next leap forward in the 300 GHz to 1 THz band.
Not really. Semiconductor development has limited the development of Far-IR. The antenna will need to be printed as a phased array of dipoles or have a parabolic reflector to make up for the very small aperture of millimetre wavelength dipoles.
FAQ: THz radiation detection with a conductor
1. What is THz radiation detection with a conductor?
THz radiation detection with a conductor is a method of detecting and measuring terahertz (THz) radiation using a conductive material as the detecting element. THz radiation, also known as T-rays, is electromagnetic radiation that falls between microwave and infrared wavelengths on the electromagnetic spectrum. It has a wide range of applications, including medical imaging, security screening, and communication technology.
2. How does THz radiation detection with a conductor work?
In this method, the conductive material is placed in the path of THz radiation. When the radiation interacts with the material, it causes a change in the material's electrical properties, such as its conductivity or resistance. This change can then be measured and used to detect and analyze the THz radiation.
3. What are the advantages of using a conductor for THz radiation detection?
Using a conductor for THz radiation detection has several advantages. First, it is a non-invasive and non-destructive method, making it suitable for many applications. Additionally, conductive materials are readily available and can be easily integrated into existing detection systems. They also have a high sensitivity to THz radiation, allowing for accurate measurements.
4. What types of conductive materials are commonly used for THz radiation detection?
The most commonly used conductive materials for THz radiation detection are metals, such as gold, copper, and aluminum. These materials have high electrical conductivity and are easily shaped into different structures, making them ideal for detecting THz radiation. Other types of conductive materials, such as carbon nanotubes and graphene, are also being explored for their potential in THz detection.
5. What are the challenges of THz radiation detection with a conductor?
One of the main challenges of THz radiation detection with a conductor is the design and fabrication of the detecting element. The size and shape of the conductor can greatly affect its sensitivity and response to THz radiation. Additionally, interference from other sources, such as thermal noise, can also affect the accuracy of the measurements. Therefore, careful consideration must be given to the design and calibration of the detection system to ensure reliable results.
