mikko paatainen
- 1
Is it possible to search for a word on a document after I have sent it to my ti-nspire cx cas calculator?
The Ti-nspire cx cas search function is a feature on the Ti-nspire cx cas calculator that allows users to search for specific terms or equations within the calculator's operating system or stored documents.
To access the search function, simply press the "menu" button on the calculator and then select "search" from the menu options. Alternatively, you can also press the "ctrl" and "f" keys at the same time to access the search function.
Yes, the Ti-nspire cx cas search function allows you to search for specific equations, variables, or keywords within your saved documents. This can be especially helpful when trying to locate a specific equation or variable in a large document or set of notes.
Yes, the search function on the Ti-nspire cx cas calculator can display up to 10 search results at a time. However, you can use the arrow keys to scroll through additional results if there are more than 10 matches.
No, the Ti-nspire cx cas search function is only designed to search within the calculator's operating system and saved documents. It cannot be used to search for terms or equations online.
