MHB Tia's question at Yahoo Answers (Derivative of f^{-1})
  • Thread starter Thread starter Fernando Revilla
The discussion focuses on proving that the function f(x) = x^3 - 1 is one-to-one by demonstrating that if f(s) = f(t), then s must equal t, confirming injectivity. It also establishes that f is surjective, as for any real number y, there exists an x such that y = f(x). Consequently, f is bijective, allowing the definition of its inverse function, f^{-1}(x) = √[3]{x^3 + 1}. The derivative of the inverse function is derived as (f^{-1})'(x) = x^2 / √[3]{(x^3 + 1)^2} for x ≠ -1. This comprehensive explanation aids in understanding the properties of the function and its inverse.
Fernando Revilla
MHB
Here is the question:
**Show that f is one-to-one on its domain.
**Find the derivative of f^-1, where f^-1 is the inverse function of f.
The "-1" is not being raised to anything in the first part (meaning f(x)=x^3-1) by the way, just the "3", please help with this and show how to work it, I am soo lost, would really appreciate it. Thanks.
Here is a link to the question:
Consider the function f(x)=x^3-1...? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Tia, $$\begin{aligned}f(s)=f(t)&\Rightarrow s^3-1=t^3-1\\&\Rightarrow s^3=t^3\\&\Rightarrow \sqrt[3]{s^3}=\sqrt[3]{t^3}\\&\Rightarrow s=t\\&\Rightarrow f\mbox{ is injective}\end{aligned}$$ On the other hand, consider $y\in\mathbb{R}$. Let's see that there exists $x\in\mathbb{R}$ such that $y=f(x)$ (i.e. $f$ is surjective) $$\begin{aligned}y=f(x)&\Leftrightarrow y=x^3-1\\&\Leftrightarrow x^3=y+1\\&\Leftrightarrow x=\sqrt[3]{y^3+1}\end{aligned}$$ So, $f:\mathbb{R}\to \mathbb{R}$ is bijective and $f^{-1}(x)=\sqrt[3]{x^3+1}$. Then, $$\left(f^{-1}\right)'(x)=\ldots=\frac{x^2}{\sqrt[3]{(x^3+1)^2}}\qquad (x\neq -1)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
