xosteve
- 2
If the lithosphere were suddenly removed, would the earthtide amplitude of the mantle be larger than the .25m or so now measured for the lithosphere?
D H said:Except for the liquid outer core and little pockets of liquid magma, the Earth is not liquid. The mantle is solid. Plastic, but solid.
Shootist said:The reason the mantle is plastic isn't because its temperature is below that necessary to melt rock; its plasticity is a result of the enormous pressure of the overlying formations containing it.
One suggests that if the crust were suddenly removed (one does not suggest the mechanism), the plastic mantle would experience catastrophic out gassing, and explosive decompression, resulting in a transition from hot and plastic to hot and liquid (melted), and hot and gaseous.
billiards said:It's only plastic over long time scales - it's viscoplastic - it's elastic over the time scales of the elastic waves you get from earthquakes.
Why is it like that? Pressure is a factor, temperature is a factor, chemistry is a factor, and mineralogy is a factor. Putting it all together is extremely difficult, people are doing novel research into this as we read/type.
Who's one?
What evidence does "one" have to support their hypothesis?
The tidal amplitude on a molten earth refers to the difference in water level between high and low tides caused by the gravitational pull of the moon and sun on a planet that is mostly or entirely covered in molten lava.
Tidal amplitude on a molten earth is significantly higher than on a solid earth due to the lack of landmasses and the fluidity of the surface. This allows for greater tidal bulges to form, resulting in larger differences in water level between high and low tides.
The main factors that affect tidal amplitude on a molten earth are the mass and distance of the moon and sun, as well as the rotation and composition of the planet's molten surface. These factors determine the strength of the gravitational pull and the extent of tidal bulges formed.
The molten surface of a planet allows for greater tidal deformations due to its fluid nature, resulting in higher tidal amplitudes. The composition and temperature of the molten lava can also impact the strength and extent of tidal bulges, affecting tidal amplitudes.
Studying and understanding tidal amplitude on a molten earth can provide valuable insights into the formation and evolution of planets, as well as the effects of extreme conditions on tidal forces. It can also have practical applications, such as in predicting the behavior of tidal forces on other planets and moons in our solar system.
