Tides are influenced by the moon
  • Thread starter sparky8406
  • Tags
    Moon Tides
In summary, tides are primarily caused by the gravitational pull of the moon and the sun on the Earth's oceans. The moon's gravitational force is stronger due to its proximity, resulting in two high tides and two low tides every day as the Earth rotates. The moon's phase also affects tides, with full and new moons causing stronger tides known as spring tides, and first and third quarter phases causing weaker tides known as neap tides. Tides can occur in bodies of water other than the ocean, but they are smaller in comparison. The moon's influence on tides can also be seen on land through the rise and fall of water levels, changes in groundwater, and small movements in the Earth's crust
sparky8406
I have a question about tides. I just read an article that states tides are influenced by the moon, sun.planets and stars. I have no problem with understanding the moon and sun, maybe the closest two planets, but the stars??! Does anyone know if that is factual and if so, how is it? Thanks
Astronomy news on Phys.org
No, stars have no effect on the tides.
In theory other planets have an effect but it is infinitessimal compared to the moon and sun.
Thank you
Related to Tides are influenced by the moon
What causes tides to occur?
Tides are primarily caused by the gravitational pull of the moon and the sun on the Earth's oceans. The moon's gravitational force is stronger since it is closer to the Earth, which is why the moon has a greater influence on tides.
How does the moon affect tides?
The moon's gravitational pull creates bulges of water on opposite sides of the Earth, causing high tides. As the Earth rotates, these bulges move, causing the water level to rise and fall, resulting in two high tides and two low tides every day.
Does the moon's phase affect tides?
Yes, the moon's phase does affect tides. When the moon is at its full or new phase, its gravitational pull is strongest, resulting in higher high tides and lower low tides, known as spring tides. When the moon is at its first or third quarter phase, its gravitational pull is weaker, resulting in lower high tides and higher low tides, known as neap tides.
Do tides only occur in the ocean?
No, tides can also occur in large bodies of water such as lakes and even in the Earth's crust. However, the tides in these bodies of water are much smaller compared to ocean tides due to the ocean's larger size and its ability to freely move in response to gravitational forces.
Can the moon's influence on tides be seen on land?
Yes, the moon's influence on tides can be seen on land through the rise and fall of water levels in estuaries, bays, and channels. It can also affect the height of groundwater and cause small movements in the Earth's crust, known as earth tides.
