tzo
- 1
Hi all,
I'm trying to solve a problem in Ashcroft - Mermin "Solid State Physics", Chapter 10: The Tight-Binding Method, and need your help.
In problem 2(c) it says:
For a face-centered Bravais lattice with only nearest-neighbor [itex]\gamma_{ij}[/itex] appreciable, show that the energy bands are given by the roots of
[itex]0 = \begin{vmatrix}
\varepsilon(\vec{k})-\varepsilon^{0}(\vec{k})+4\gamma_{0}\cos\frac{1}{2}k_{y}a\cos\frac{1}{2}k_{z}a & -4\gamma_{1}\sin\frac{1}{2}k_{x}a\sin\frac{1}{2}k_{y}a & -4\gamma_{1}\sin\frac{1}{2}k_{x}a\sin\frac{1}{2}k_{z}a \\
-4\gamma_{1}\sin\frac{1}{2}k_{y}a\sin\frac{1}{2}k_{x}a & \varepsilon(\vec{k})-\varepsilon^{0}(\vec{k})+4\gamma_{0}\cos\frac{1}{2}k_{z}a\cos\frac{1}{2}k_{x}a & -4\gamma_{1}\sin\frac{1}{2}k_{y}a\sin\frac{1}{2}k_{z}a\\
-4\gamma_{1}\sin\frac{1}{2}k_{z}a\sin\frac{1}{2}k_{x}a & -4\gamma_{1}\sin\frac{1}{2}k_{z}a\sin\frac{1}{2}k_{y}a & \varepsilon(\vec{k})-\varepsilon^{0}(\vec{k})+4\gamma_{0}\cos\frac{1}{2}k_{x}a\cos\frac{1}{2}k_{y}a
\end{vmatrix}[/itex]
where
[itex]
\varepsilon^{0}(\vec{k})={E}_{p}-\beta-4\gamma_{2}(\cos\frac{1}{2}k_{x}a\cos\frac{1}{2}k_{z}a+\cos\frac{1}{2}k_{x}a\cos\frac{1}{2}{k}_{y}a+\cos\frac{1}{2}k_{y}a\cos\frac{1}{2}k_{z}a),\\
\gamma_{0}=-\int d \vec{r}[{x}^{2}-y(y-\frac{1}{2}a)]\phi(r)\phi(\sqrt{{x}^{2}+(y-\frac{a}{2})^{2}+(z-\frac{a}{2})^{2}})\Delta U(\vec{r}),\\
\gamma_{1}=-\int d \vec{r}(x-\frac{1}{2}a)(y-\frac{1}{2}a)\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+(y-\frac{a}{2})^{2}+{z}^{2}})\Delta U(\vec{r}),\\
\gamma_{2}=-\int d \vec{r}x(x-\frac{1}{2}a)\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+(y-\frac{a}{2})^{2}+{z}^{2}})\Delta U(\vec{r}).
[/itex]
I could derive diagonal terms properly, but off-diagonal terms, for example (1,2)-entry, become :
[itex]4 \gamma_{1}\cos\frac{1}{2}k_{x}a\cos\frac{1}{2}k_{y}a[/itex]
Below is my derivation. Could you tell me where I made a mistake?
http://dileepma.tripod.com/cha10.pdf
(1,2)-entry[itex] = \beta_{xy}+\widetilde{\gamma}_{xy}(\vec{k})\\[/itex]
[tex]
=0+\sum_{n.n.}e^{i\vec{k}\cdot\vec{R}}[-\int d \vec{r} \psi_{x}^{*}(\vec{r})\psi_{y}(\vec{r}-\vec{R})\Delta U(\vec{r})]\\
[/tex][itex]
= e^{i(\frac{1}{2}k_{x}a+\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y+\frac{a}{2})\phi(r)\phi(\sqrt{(x+\frac{a}{2})^{2}+(y+\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r}))\\
+ e^{i(\frac{1}{2}k_{x}a-\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y-\frac{a}{2})\phi(r)\phi(\sqrt{(x+\frac{a}{2})^{2}+(y-\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r}))\\
+ e^{i(-\frac{1}{2}k_{x}a+\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y+\frac{a}{2})\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+(y+\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r}))\\
+ e^{i(-\frac{1}{2}k_{x}a-\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y-\frac{a}{2})\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+(y-\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r}))\\
+ e^{i(\frac{1}{2}k_{x}a+\frac{1}{2}k_{z}a)}(-\int d \vec{r} xy\phi(r)\phi(\sqrt{(x+\frac{a}{2})^{2}+{y}^{2}+(z+\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(\frac{1}{2}k_{x}a-\frac{1}{2}k_{z}a)}(-\int d \vec{r} xy\phi(r)\phi(\sqrt{(x+\frac{a}{2})^{2}+{y}^{2}+(z-\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(-\frac{1}{2}k_{x}a+\frac{1}{2}k_{z}a)}(-\int d \vec{r} xy\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+{y}^{2}+(z+\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(-\frac{1}{2}k_{x}a-\frac{1}{2}k_{z}a)}(-\int d \vec{r} xy\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+{y}^{2}+(z-\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(\frac{1}{2}k_{y}a+\frac{1}{2}k_{z}a)}(-\int d \vec{r} x(y+\frac{a}{2})\phi(r)\phi(\sqrt{{x}^{2}+(y+\frac{a}{2})^{2}+(z+\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(\frac{1}{2}k_{y}a-\frac{1}{2}k_{z}a)}(-\int d \vec{r} x(y+\frac{a}{2})\phi(r)\phi(\sqrt{{x}^{2}+(y+\frac{a}{2})^{2}+(z-\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(-\frac{1}{2}k_{y}a+\frac{1}{2}k_{z}a)}(-\int d \vec{r} x(y-\frac{a}{2})\phi(r)\phi(\sqrt{{x}^{2}+(y-\frac{a}{2})^{2}+(z+\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
+ e^{i(-\frac{1}{2}k_{y}a-\frac{1}{2}k_{z}a)}(-\int d \vec{r} x(y-\frac{a}{2})\phi(r)\phi(\sqrt{{x}^{2}+(y-\frac{a}{2})^{2}+(z-\frac{a}{2})^{2}} )\Delta U(\vec{r}))\\
=e^{i(\frac{1}{2}k_{x}a+\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y+\frac{a}{2})\phi(r)\phi(\sqrt{(x+\frac{a}{2})^{2}+(y+\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r}))\\
+ e^{i(\frac{1}{2}k_{x}a-\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y-\frac{a}{2})\phi(r)\phi(\sqrt{(x+\frac{a}{2})^{2}+(y-\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r}))---- (*)\\
+ e^{i(-\frac{1}{2}k_{x}a+\frac{1}{2}k_{y}a)}(-\int d \vec{r} x(y+\frac{a}{2})\phi(r)\phi(\sqrt{(x-\frac{a}{2})^{2}+(y+\frac{a}{2})^{2}+z^2} )\Delta U(\vec{r})) ----(*)\\
+ 8 \cdot 0\\
=4 \gamma_{1}\cos\frac{1}{2}k_{x}a\cos\frac{1}{2}k_{y}a
[/itex]
I'm suspecting that two starred terms in second last equation has negative sign.
Thanks.
where
[itex]
[/itex]
[tex]
[/tex][itex]
+ 8 \cdot 0\\
[/itex]
Thanks.
