TikZ 2.10: atan2 Redefined - Test it Out
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Test
In summary, those who have made diagrams in TikZ 2.10 should be aware that the previous version's atan2 has been redefined. This means that any code built off the old definition may still compile, but the output may not match expectations. The new definition is atan2(\y2-\y1, \x2-\x1), as opposed to the previous atan2(\x2-\x1, \y2-\y1). To test this out, one can compile an example from the sub forum and then change the definition to see the difference in output. It may seem confusing at first, but it's important to note when transitioning to TikZ 2.10.
Dustinsfl
2,281
For those who have made diagrams in TikZ 2.10, the previous version, atan2 has be redefined. Therefore, any code built off the old definition will compile but the output may not be what you expect.
Before it was atan2(\x2-\x1, \y2-\y1).
Now it is atan2(\y2-\y1, \x2-\x1).
If you want to test it out, compile one of my examples in this sub forum that uses atan2. Then change it to the correct definition.
You will see that the output is different. It may be a bit confusing at first, but it's something you should be aware of when transitioning to TikZ 2.10.
FAQ: TikZ 2.10: atan2 Redefined - Test it Out
What is TikZ 2.10?
TikZ 2.10 is a package for creating graphics and diagrams in LaTeX. It is widely used in the scientific community for its versatility and ability to produce high-quality visuals.
What is atan2 and how is it redefined in TikZ 2.10?
atan2 is a mathematical function that calculates the arctangent of a given point's coordinates. In TikZ 2.10, atan2 is redefined to provide more accurate results and better handling of special cases.
How can I test out the new atan2 function in TikZ 2.10?
To test out the new atan2 function, you can create a simple graph or diagram using the TikZ package and include the atan2 function in your code. Then, compare the results with the previous version of TikZ to see the improvements.
What are the benefits of using TikZ 2.10's atan2 function?
The benefits of using the new atan2 function in TikZ 2.10 include increased accuracy and improved handling of special cases, such as points on the x-axis or y-axis.
Are there any known issues or limitations with TikZ 2.10's atan2 function?
While the new atan2 function in TikZ 2.10 is generally more accurate and reliable, there may still be some edge cases where it may not produce the desired results. It is always recommended to test and verify your graphs and diagrams before using them in a professional setting.
