MHB TikZ Challenge 1 - Geometrical Diagram - Votes
A challenge was held to create impressive geometrical diagrams using TikZ, with voting open for two weeks. Participants submitted various diagrams showcasing different mathematical concepts, including triangles, direction fields, and trigonometric foundations. The voting concluded with 15 participants, and the results announced MarkFL as the winner, followed by Serena, lfdahl, and greg1313. The thread celebrated all contributors for their efforts and creativity in the challenge. The discussion has now been closed.
What is the best TikZ contribution for a geometrical diagram?
  • Total voters
  • Poll closed .
I like Serena
MHB
Hey all,
2 weeks ago I created a challenge to create a geometrical diagram, like a triangle, that is somehow interesting or impressive.
Now the moment of truth is here. Please everyone, give your vote!
Voting will close in 2 weeks time.
Let me recap the submissions.I like Serena
\begin{tikzpicture}[blue]
\coordinate (A) at (0,0);
\coordinate (B) at (4,0);
\coordinate (C) at (4,3);
\draw[blue, ultra thick] (A) -- (B) -- (C) -- cycle;
\path (A) node[below left] {A} -- (B) node[below right] {B} -- (C) node[above] {C};
\path (A) -- node[below] {c} (B) -- node
{a} (C) -- node[above left] {b} (A);
\path (A) node[above right, xshift=12] {$\alpha$};
\draw[thick] (B) rectangle +(-0.4,0.4);
\draw[thick] (A) +(1,0) arc (0:atan(3/4):1);
\end{tikzpicture}
[latexs]
\end{tikzpicture}
[/latexs]
This picture is special because it's a basic shape that showcases:
  1. Naming coordinates.
  2. Drawing a closed polygon.
  3. Embellishing with properties (for color and thickness).
  4. Adding labels next to nodes and next to lines.
  5. Specifying relative coordinates.
  6. Drawing an arc.
  7. Using a mathematical function (for the angle of the arc).
greg1313
\begin{tikzpicture}[scale=2]
\usetikzlibrary{calc}
\coordinate (B) at (1,2.5);
\coordinate (C) at (4,0);
\draw (A) -- (B) -- (C) -- cycle;
\draw (B) -- ($(A)!(B)!(C)$) ++(90:0.2) -- ++(0:0.2) -- +(-90:0.2);
\draw (A) -- ($(B)!(A)!(C)$) ++(-39.806:0.2) -- ++(50.194:-0.2) -- +(-39.806:-0.2);
\draw (C) -- ($(A)!(C)!(B)$) ++(68.2:-0.2) -- ++(-21.8:0.2) -- +(68.2:0.2);
\draw (A) node
{$A$} -- (B) node[above]{$B$}node[midway,above]{$c\quad$} -- (C)node
{$C$}node[midway,above]{$\quad a$} -- (A)node[midway,below]{$b$};
\node[align=center,font=\bfseries, yshift=2em] (title)
at (current bounding box.north)
{An illustration of the altitudes of a triangle, \\ intersecting at a single point called the orthocenter};
\end{tikzpicture}
[latexs]
\draw (A) node
\end{tikzpicture}
[/latexs]
This TikZ diagram includes a title.MarkFL
\begin{tikzpicture}
\draw[<->][red] (-5.5,0) -- (5.5,0) node
{$x$};
\draw[<->][red] (0,-5.5) -- (0,5.5) node[above] {$y$};
\foreach \x in {-5,-4.5,...,-0.5,0.5,1,...,5}
\foreach \y in {-5,-4.5,...,-0.5,0.5,1,...,5}
\def \angle {atan((3*\x*\y)/(2*(\x)^2-(\y)^2))};
\draw[thick,blue] ({\x + 0.1*cos(\angle)},{\y + 0.1*sin(\angle)}) -- ({\x + 0.1*cos(\angle + 180)},{\y + 0.1*sin(\angle + 180)});
\end{tikzpicture}
[latexs]
\begin{tikzpicture}
{$x$};
\end{tikzpicture}
[/latexs]
This TikZ diagram illustrates a direction field for a magnetic dipole, and utilizes the following:
  • Nodes for the axis labels.
  • Nested foreach loops.
  • The definition of an angle (slope) based on coordinates.
  • Parametric values for the endpoints of line segments.
lfdahl
[TIKZ][scale=3]
\draw[step=.5cm, gray, very thin] (-1.2,-1.2) grid (1.2,1.2);
\filldraw[fill=green!20,draw=green!50!black] (0,0) -- (3mm,0mm) arc (0:30:3mm) -- cycle;
\draw[->] (-1.25,0) -- (1.25,0) coordinate (x axis);
\draw[->] (0,-1.25) -- (0,1.25) coordinate (y axis);
\draw (0,0) circle (1cm);
\draw[very thick,red] (30:1cm) -- node[left,fill=white] {$\sin \alpha$} (30:1cm |- x axis);
\draw[very thick,blue] (30:1cm |- x axis) -- node[below=2pt,fill=white] {$\cos \alpha$} (0,0);
\draw (0,0) -- (30:1cm);
\foreach \x/\xtext in {-1, -0.5/-\frac{1}{2}, 1}
\draw (\x cm,1pt) -- (\x cm,-1pt) node[anchor=north,fill=white] {$\xtext$};
\foreach \y/\ytext in {-1, -0.5/-\frac{1}{2}, 0.5/\frac{1}{2}, 1}
\draw (1pt,\y cm) -- (-1pt,\y cm) node[anchor=east,fill=white] {$\ytext$};
[/TIKZ]
[latexs]
[TIKZ][scale=3]
[/TIKZ]
[/latexs]
This TikZ picture is special, because it demonstrates:
- The very foundation of trigonometry
- Construction of a coordinate system
- Construction of a grid
- Coloring of line segments
- The making of tick labels
- How to fill in with colors
- How to use different line thickness
- How to position labels​
Mathematics news on Phys.org
Voting is over.
Thank you all for taking the time to take a look and vote. We have 15 voters!
The result:
  1. MarkFL
  2. I like Serena
  3. lfdahl
  4. greg1313
A big hurray for every one of the contributors. Thank you for your efforts!
Thread closed.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
